So we have recently moved onto high speed machining toolpaths and we've quickly found out the limiitations of our machines are memory capacity. We have just purchased a DNC ONE box via rs232 and are attempting to use it on our Takumi V8a mill with Meldas 500 (520AMR?) controls. The drip feed works fantastic when it works which is inconsistent because sometimes it will run 10% of the program and sometimes 60%, however we are running into a P460 Tape I/O Error.
DNC ONE Defaults are Data Bits: 7 Parity: Even Stop Bits: 2 Baud rate: 9600 I'm not sure on the pinout of the cable however I can test that in the meantime.
I'm not too sure how to check all the settings on the mill but I know the baud rate is 9600.
We are concerned with the error as well as the ability to press the cycle hold button and then resume the program at any time to be able to prove out programs and to double check clearances.
Could the error be caused by pressing the cycle hold button while running in tape mode?
My knowledge on the software communications is not great however I will provide as much info as I can find! Thanks!
P.S. I have attached some photos if that is of any help to anyone
