585,754 active members*
3,750 visitors online*
IndustryArena Forum > CAM Software > CamBam > CamBam Gcode output
    Jun 2009
    11
    CamBam Gcode output
    hello!
    I am trying to create a faster way to produce gcode using CamBam for my machine which runs WinCNC. I am finding that I need to modify the output which can be tedious. Here is an example of the modification I did on the last test
    run
    Attachment 356860
    Attachment 356858
    I see that there is the option for post processor but none of those options are outputting what i need. Is there anyway to make this automatic or am I stuck with a manual process?
    Any help would be greatly appreciated!!
    Mark
    Dec 2013
    5717
    Re: CamBam Gcode output
    It's very easy to modify a CamBam post to output anything you want. Click on the System tab, choose Post Processors, and in your case, I would choose the Fanuc post. Modify as needed, and save to a different file name. Then reload the post processors from Tools, Reload post processors. Then set your new post processor as default.
    In the Help menu, click on Content, when the page opens, click on Post Processors on the left. There are extensive instructions and all of the codes.
    Jul 2016
    660
    Cambam is the only software that I know that can do replicating job precisely and accurately, a simple 3 axis CNC machine can behave like the million dollar ATC CNC`s with only one tool bit.
    Attachment 356908
    (sorry altamont im just doing my job)
    I did this under 15 minutes a pair with just one tool bit, nobody said Cambam is easy, but if you can get a grasp of the software, you can be a successful spindle manipulator, build, copy, make any product of your own with a fastest time ever on a very simple set-up.
    The original machining on this product took them 4-5 tool bits, I can see it in the tool marks on the product.
    Im planning to modify another CNC machine to adopt much bigger NEMA motors to surpass the current 3000 FRO, for me the 3000 mark is not enough anymore, I want it to be faster now, hopefully the 6000 barrier.
    Jun 2009
    11
    Awesome, thanks Jim! This is a powerful tool, thank you for the insight it worked perfectly!
    Dec 2013
    5717
    Happy to be of some help
  1. Replies: 2
    Last Post: 01-14-2016, 06:49 PM
  2. MACH3 interpreting CAMBAM GCODE wrong
    By jsearles in forum CamBam
    Last Post: 09-30-2012, 02:45 AM
  3. Importing CamBam Gcode into Kcam
    By hondaman900 in forum Uncategorised CAM Discussion
    Last Post: 05-23-2010, 07:31 AM
  4. Replies: 2
    Last Post: 03-30-2010, 12:52 AM
  5. does deskam only output metric gcode?
    By july_favre in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-23-2004, 09:44 PM
