585,604 active members*
3,412 visitors online*
    Oct 2015
    15
    Proximity Sensor Locations
    Hi All,
    Hoping to get some guidance regarding the proximity sensor locations. The only two obvious one's i can make out are on the Gantry supports.
    Where do the rest go?
    Jul 2007
    139
    Re: Proximity Sensor Locations
    There's slots on the z axis and x axis plates that will fit the sensors. They're the only parts with large slots
    Jun 2007
    3891
    for the X its on the gantry upright, using a screw in a t slot as the pickup point. so, 1 sensor, and 1 (home) or 2 (each end hard limit) pickups.
    for the y and z its done a bit odd. they y (gantry cross) theres is meant to be 1 or 2 sensors on the back plate that pick up the aluminium moving y saddle/ ball nut mount. one sensor for each end. this works. realistically, you just need one sensor for home, and then use soft limits.
    the z is the same as the y, but its got one switch meant to pick up the z saddle at the top (home).
  1. CRP's Proximity Sensor Kit
    By rwskinner in forum Avid CNC
    Last Post: 02-12-2014, 04:07 AM
  2. Help with NPN proximity sensor wiring in parallel
    By bean_086 in forum DIY CNC Router Table Machines
    Last Post: 08-09-2013, 04:44 PM
  3. Proximity sensor or home/limits?
    By kevincnc in forum DIY CNC Router Table Machines
    Last Post: 01-18-2013, 05:43 PM
  4. BB does not read +5 from proximity sensor
    By crane550 in forum DIY CNC Router Table Machines
    Last Post: 03-25-2012, 02:01 PM
  5. proximity sensor issue
    By strohkirchw in forum Benchtop Machines
    Last Post: 05-27-2011, 10:14 PM
