585,715 active members*
3,786 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > Animating a Terminator
Results 1 to 6 of 6
    Mar 2017
    164
    Hi all , I have a full scale Arnold that I've been building , and will be moddimg to look like the battle damaged version in the movie .
    Here he is here in my basement . The last pic is a 1/6th scale of how he's supposed to look .
    I have most of the parts other than the battle damaged knee .
    I'm thinking of making the battle damaged arm moving at the shoulder and elbow . Basically use the mannequin as a mold and make new parts with joints .
    I think it would be cool to have some degree of rotational movement in the waist also.
    Would you guys use servos or steppers for movement in the arm ?
    When steppers loose power , I believe they also lose there ability to hold, and when they power up again , would they go back to there previous locations ?
    Another option would be geared servos or I believe somewhere I've seen geared Stepper motors .
    I think steppers sound better robotically, and would be more realistic
    Dec 2013
    5717
    Re: Animating a Terminator
    Quote Originally Posted by MajorTendonitis View Post
    Very cool project !
    Steppers would be fine. And as you say below, the sound would add to the effect.
    Steppers have some, but very small, holding ability when powered off. To get them to go back to their previous location when powered on will require an absolute encoder attached to the stepper, and full computer control. There are gearboxes available for steppers, look on Ebay for geared steppers. With a gearbox, there will probably be enough resistance to prevent movement when powered off.
    Once you get the mechanics worked out, then comes the real fun of getting it all under computer control. There are many options available for this type of project. The degree of sophistication depends on your budget. I would use a stand alone motion controller for this type of project. Small enough to install in the body and no external computer required.
    Looking forward to following your progress
    Mar 2017
    164
    Thanks for the post Jim . I have had limited success with computer stamps before . Used stamps from parallax to run servos with PWM years ago.
    I've never played with steppers before , but am collecting parts to build a CNC router . I thought seeing as I'm going to learn about steppers , that maybe they will be less intimidating, and I could implement them in Arny .
    My concern was if the damaged endo arm relaxed after being powered off , and when it got the on command , would it go back to it's original location and take a kids eye out or something.
    I'm going to look at geared steppers and as you say , try and keep a simple system internally that does not require a full blown computer, other than programming .
    All I basically want is some random movements , as I thought it would make for a cool effect
    Apr 2004
    5734
    If you want your stepper motors to stop moving, you just stop sending them motion pulses. You don't have to turn the power off to them; they have their maximum torque when holding still. If you do turn off the power to something like an outstretched arm, expect it to drop. (A stepper gear-motor may not, depending on how easy it is to back-drive the gears). But in an open-loop stepper system, it won't return to the previous position when power is restored. But if you want to avoid injury to bystanders, keep them out of harm's way - like any automatic machine, your robot might do unexpected things.
    Andrew Werby
    Website
    Mar 2017
    164
    Quote Originally Posted by awerby View Post
    Yes this is my concern ,as the 3 laws of robotics don't apply to Terminators lol
    Dec 2013
    5717
    Stamps will work perfect for what you want to do. Actually much easier to control steppers than servos with them.
  1. animating 4th axis material/work
    By jay_dizzle in forum Okuma
    Last Post: 05-30-2020, 06:00 PM
  2. Siemens terminator
    By hotrob1 in forum Want To Buy...Need help!
    Last Post: 05-20-2010, 12:35 AM
