585,597 active members*
3,445 visitors online*
Thread: Gcode Z-axis
Results 1 to 7 of 7
    Apr 2017
    5
    Gcode Z-axis
    Hello,
    I'm making a cnc machine that can write. for that i'm using gcode and cambam.i have limit switches on my X and Y axis but not on my Z. I can't add switches there but now i can't home anymore because of that. Do you guys know how can can home without the Z-axis?
    Re: Gcode Z-axis
    What control software are you using?
    And why can't you home?
    Apr 2017
    5
    Re: Gcode Z-axis
    I'm using universal gcode sender for controlling the machine and Cambam for drawing things.When i press the homebutton he searches for the switches so that he knows where he is but my Z-axis has no hard limits, because of that he's stuck in homing because he can't find a switch and i can't add switches on my Z-axis.(srry if my English is not that good).
    Dec 2013
    5717
    Re: Gcode Z-axis
    Wire the X home switch to the Z home input also. That way when the X homes, the controller will think that the Z has homed also.
    Apr 2017
    5
    Re: Gcode Z-axis
    That doesn't work because he moves the Z-axis first to make sure he doesn't make contact with the paper after that he moves the X and Y. Any other suggestions?.
    15362
    Re: Gcode Z-axis
    Quote Originally Posted by ThatGuy2 View Post
    Have a micro switch setup for the Z axes, that you can hit with your hand when the Z moves to where you think it is safe,
    Mactec54
    Apr 2017
    5
    Re: Gcode Z-axis
    Thx for the help.I will do that because it's the only solution.Hope the jury won't mind that i need to do it manualy.I'm making this for my integrated test.
  1. 4th-Axis GCode Programming
    By twehr in forum G-Code Programing
    Last Post: 02-19-2023, 11:02 AM
  2. help with 5 axis gcode
    By ethank in forum Rhinocam
    Last Post: 09-25-2020, 08:05 PM
  3. Way to take gcode for one axis and mirror it for another axis?
    By genestapp in forum Uncategorised CAM Discussion
    Last Post: 10-09-2010, 04:14 PM
  4. 4th gcode axis problem
    By fabconv in forum Visual Mill
    Last Post: 08-29-2009, 01:39 PM
  5. What is the gcode to ref 1 axis home after
    By seanreit in forum Uncategorised MetalWorking Machines
    Last Post: 12-07-2008, 11:18 PM
