585,560 active members*
3,494 visitors online*
IndustryArena Forum > CAD Software > Solidworks > graduated scale from POINTS for unequally spaced CURVED SPLINE?
Results 1 to 10 of 10
    Feb 2004
    84
    I need to make an engraved analemma (see pic) and I have made a sketch and spline with the 365 X,Y coordinate data points representing each day of the year. I now would like to use these points, which I used to generate an extruded cut (the material enclosed by the 2 loops of the spline is removed), as points from which to engrave a scale like a protractor or ruler scale to indicate days of the month. I'd like to do this of course without drawing each scale line individually. The line from each point needs to be perpendicular to the cutout at that point, like the scale lines on a protractor would be, ideally each a vee extruded cut. Is there any way to do this in even a partially automated way, maybe with a macro? The points are NOT equally spaced along the spline....
    Feb 2004
    84
    Re: graduated scale from POINTS for unequally spaced CURVED SPLINE?
    Looks like I can generate these points using a macro in Excel spreadsheet and draw the lines point to point, unless someone has a better idea...
    See my stuff for sale at http://stores.ebay.com/Industrial-Tool-and-Machine-Works?refid=store
    Nov 2006
    Tom,
    I know its a bit late but can you use a "sketch driven pattern" like in the attached image? Trace over your points with a spline. Use just enough of your points to get a good representation of the curve. Now create a feature (I assume it will be an extruded cut to represent one notch) and pattern it. If for some reason this doesn't work, you may want to to make a boss extrude that isn't merged, pattern it, and then combine the patterned bodies with the main body (but select subtract).
    You will probably want to divide the curve into pieces as to not be a figure 8. I would divide it into 4 arcs, do the sketch pattern twice then mirror it.
    Make sure to choose "offset curve" and "tangent to curve".
    Brian
    Attachment 360432
    Feb 2004
    84
    I got wrapped up in some other projects so it is definitely not too late, your idea may work. I'll give it a shot soon.
    thanks!
    tom
    Mar 2008
    683
    I use this method for drawing NACA scoops. But the problem is SW will put a spline point through each point so you will get some wild inflections on the spline so it won't be smooth. Because your graduations are not equally spaced you would need to write a formula which is beyond my experience with something like this. Good luck..
    Feb 2004
    84
    I'll fool around with it, if it doesn't work I may be able to generate a data set for a slightly larger sundial and then use those points, but I don't think it will work because of the intersection. Formula may be the only way to go.
    Feb 2004
    84
    I worked on this a bit and was able to get a nice sketch driven pattern, but was NOT able to make the extruded cuts perpendicular to the spline, only parallel to each other AND the extrude is mirrored about the spline for some reason, so it cuts into the opposite side of the cutout as well.... Next attempt will be to offset the spline hopefully with the points and work from there unless anyone has a better idea. I didn't see curve driven pattern as a choice on my menu...
    Feb 2004
    84
    ACK, I'm so close now, but I can't see how to get the spacing based on my data points, only equal spacing. is there something I'm missing? I offset the inside spline, and am making a pattern of the cuts...
    Feb 2004
    84
    I see there is a table driven pattern available if I reformat my data; maybe I can get a combination of the parameters above to generate what I need using a table of those sketch points but driving from the curve. Out of time for tonight though.
    Feb 2004
    84
    OK this table driven pattern dialog is not making sense to me, I just want to use the coordinate system that is used for the drawing I already have as I'm using the same data points that the sketch was generated from, I found this video but it is only confusing me more, fast forward to :50 sec
    https://www.youtube.com/watch?v=Tre1DSOV-so
    It looks like it is expected that a whole new coordinate system would be created for this, why?
  1. easy graduated dials
    By dz1 in forum Videos
    Last Post: 03-11-2015, 02:31 PM
  2. 9x20 hand wheel graduated dial replacment or mod
    By emh114 in forum Mini Lathe
    Last Post: 01-12-2011, 03:21 AM
  3. Test on mono-spaced code
    By gar in forum Haas Mills
    Last Post: 02-12-2008, 01:58 PM
  4. Graduated
    By John3 in forum Community Club House
    Last Post: 08-19-2007, 05:03 PM
  5. Easiest method to mill equally spaced open ended slots?
    By metalworkz in forum Dolphin CAD/CAM
    Last Post: 07-23-2007, 07:50 PM
