585,906 active members*
3,623 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Puma 8HC-3A gear shifter seal kit needed
Results 1 to 8 of 8
    Jan 2008
    78
    Our Puma 8HC-3A is leaking hydraulic fluid around the actuating cylinder that moves the gear shift shaft in the head stock. We do not have any mechanical manuals, so we don't really know what is required.
    Any help in guiding us to a dealer that can help up out?
    Cheers,
    Steve E
    Feb 2013
    788
    Re: Puma 8HC-3A gear shifter seal kit needed
    Where are you located?
    What is the serial number?
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Jan 2008
    78
    Quote Originally Posted by dhardt View Post
    We are located in South East Kansas. Machine Serial: 520005
    Steve
    Feb 2013
    788
    Your dealer is Machine Tool Specialties
    918-622-0018
    I checked with the books I have on file for that series, I can't find anything on a gear-shift for the Main Spindle. Everything I found was motor to belt/pulley...no gearbox.
    Send a picture and I'll try to find a comparable unit.
    Jan 2008
    78
    Attachment 357994
    Shots of the shifter cylinder dis-assembled.
    Steve
    Feb 2013
    788
    Our spindle specialist has never seen this set-up.
    He wants to contact the Korea Factory.
    He needs a picture of the Placard, showing the model and serial number for Korea to address an issue with a machine this old (their policy, not mine)
    Please send a picture of the placard to [email protected]
    Jan 2008
    78
    Pictures are off & on their way.
    Steve E
    Feb 2013
    788
    Email changed to: [email protected]
  1. Gear Shifter Alarm - Fanuc 15M
    By megaisomot in forum Fanuc
    Last Post: 03-23-2022, 08:33 AM
  2. tech help needed, labyrinth air seal?
    By teamjnz in forum Haas Mills
    Last Post: 02-08-2016, 06:25 PM
  3. pre 90 puma 12 trans parts needed
    By ewok2759 in forum Want To Buy...Need help!
    Last Post: 03-18-2012, 04:02 AM
  4. puma 240 mastercam x post needed
    By outcastproducts in forum Daewoo/Doosan
    Last Post: 03-29-2008, 04:40 PM
  5. Puma 450 gear range?
    By wjbzone in forum Daewoo/Doosan
    Last Post: 02-15-2006, 01:15 PM
