585,727 active members*
3,873 visitors online*
    Apr 2017
    DyhaCNC 48x 48 router
    I'm working on this router for a friend. It has Candcnc controllsCan anyone help me with the following questions?
    1) Where is home position on the table as you llok from the front?
    2) Where can I find a Manual for this?
    3) Where can I find a Mach3 XML file?
    Thank you in advance.
    Gary
    Jun 2008
    562
    Re: DyhaCNC 48x 48 router
    1. Home should be left front corner closet to you while looking at machine from front.
    2.?? Depends on which series controller you have. Candcnc I believe was the 1000 or 4000 series, I have a 4000 series manual if that is the one you have.
    3. See attachment. It is for a 6000 series but I believe it will work.
    Attached Files Attached Files
    Jul 2005
    2415
    We only made a few full controllers for DynaCNC. They are all in a Fiberglas case. ALl others were either made by Dyna in house or they were built by another contractor . The 1000 series was the PC interface (BOB) and on plasma systems the THC. Part of the problem was that Dyna never upgrade from MACH 2.XX series to 3.XX series on their systems so a lot of the MACH3 files won't work. They took profiles we wrote and modified them to work on their tables rather than upgrade.
    Higher number series of Dyna were not any of our electronics.
    If it is a 1000 "basic" You might check on our website at Manuals – CandCNC and the obsolete section. Also the downloads for possuble MACH profiles (XML's) and screen sets. You can use a generic MACH profile and set you motors outputs port 1 to X step = 2 X dir =3 then the other axis are y 3 and 4 and Z 5 & 6 and A (if used for slaving) as 7 & 8. Motor tuning will be a "set and try" method for the steps per unit and velocity.
  1. Replies: 7
    Last Post: 10-13-2015, 07:28 PM
  2. Steel Router Mount for Milwaukee 5625 Router
    By sharbold in forum For Sale Only
    Last Post: 06-22-2015, 09:47 PM
  3. Mini cnc router Wood cnc router Sinomac S8- mini hoby cnc router 0609
    By Winni-Sinomac06 in forum Commercial CNC Wood Routers
    Last Post: 04-14-2015, 03:07 AM
  4. 4x10 Homemade router table - CNC router parts
    By graphicideas1 in forum For Sale Only
    Last Post: 11-05-2014, 02:30 AM
