Good Day everybody,
I bought a mc-800vf, but i see after installation i have a play on the work table, is not from the ballscrew it from x Axis slide.
Some body know if i can repair it or the machine is good for garbage?
Eric
Good Day everybody,
Eric
Just about anything can be repaired, it depends on what the problem is. You have to find what is loose.
ok, i work on it a little, i remove the gib block and it is a angle piece for remove the play, is made on steel and plastic and the plastic parts it's slide on the ways. i thing i will remove the table to clean the oïl hole. the ways is ishhh.
