585,996 active members*
4,679 visitors online*
    Jun 2016
    18
    thread milling
    does anyone know how to make partmaster output the threadmilling program in radius programing rather than straight increments? files size is gnarly and its not possible to adjust thread diameter using tool offsets.
    Jun 2016
    18
    Re: thread milling
    i was able to alter my post processor to do what i original asked however if i try and make my depth over .19 it pops up with an error saying that the number of axial passes is to small
    Jul 2010
    180
    Re: thread milling
    Quote Originally Posted by ORCOGUNWORKS View Post
    PM3D is a licence issue. You set radius or diameter output in the machine setup. Adjust tool offset... not sure what you are talking about. Cam doesn't concern itself with offsets, that's your controllers job.
    You would do better to ask Dolphin directly rather than here. There support through Andre and Michael is very good.
    Jun 2016
    18
    Re: thread milling
    figured it out myself with a little googling i got lucky. deleted a line in the post processor which was causing it to output my circles using a series of straight line movements rather than radius programming (iow it was spitting out X,Y movements and a whole lot of them not I,J movements) i was able to find an older download of partmaster 14 and reinstall pm3d from that. and as far as the axial passes to small it turned out to be a simple tool setting as dolphin checks everything in the tool file including cut depth and flute length.
    Feb 2007
    412
    Re: thread milling
    Hello,
    We have standalone app in development that creates Tapered threads and also Fusee type threads for watch & clock makers.
    I'll keep you posted.
    ATB
    Andre
  1. Thread milling a 1/8-27 npt internal thread
    By Slick27 in forum BobCad-Cam
    Last Post: 02-17-2016, 07:58 AM
  2. Npt thread milling
    By jredbolurne in forum GibbsCAM
    Last Post: 02-10-2016, 06:02 PM
  3. Thread Milling 3/8-18 NPT
    By UniqueMachining in forum Novakon
    Last Post: 01-26-2016, 08:59 PM
  4. Thread Milling
    By cncClintain in forum Mastercam
    Last Post: 05-23-2011, 02:12 PM
  5. Thread milling
    By wjfiles in forum MetalWork Discussion
    Last Post: 01-08-2007, 11:13 PM
