585,982 active members*
4,580 visitors online*
    Jan 2016
    53
    Help needed configuring for two Z steppers
    I downloaded Marlin firmware version 1.1.0 RC 8 and flashed this to my laserBot laser machine which has a MegaPi controller board. The laserBot is now working fine.
    I have a 3D printer frame sitting in my shop not being used which is the classic i3 Prusa type with the dual Z axis stepper motors. I am trying to convert this into a laser machine by installing a MegaPi controller board and flashing the same Marln firmware RC 8.
    I uncommented the line in config adv.h
    Z_DUAL_STEPPER_DRIVER
    ...but got a compiler error: pins.h:449: error: 'E1_STEP_PIN' was not declared in this scope.
    Does anyone know how to resolve this?
    My understanding is that if I can enable a second Z stepper, the 4th (and last) remaining port on the MegaPi will work the second Z stepper. I have yet to test that theory however.
    Thanks...
    Re: Help needed configuring for two Z steppers
    Use a Arduino Mega 250 and RAMPS board - that definitely works without grief
  1. Replies: 3
    Last Post: 06-25-2015, 06:30 PM
  2. Help needed. Steppers not responding
    By Avshez in forum Mach Software (ArtSoft software)
    Last Post: 12-09-2012, 06:00 PM
  3. Small Steppers and Electronics Help Needed
    By RMS in forum DIY CNC Router Table Machines
    Last Post: 10-20-2010, 05:30 AM
  4. steppers info needed and advice
    By zeljko-zagreb in forum Open Source Controller Boards
    Last Post: 02-14-2008, 06:17 AM
  5. Info needed on steppers
    By kayakman in forum DIY CNC Router Table Machines
    Last Post: 12-28-2003, 05:44 PM
