585,567 active members*
3,404 visitors online*
Results 1 to 7 of 7
    May 2014
    174
    915 SRAM PARITY - SISTEM ALARM
    Dear friends. One of those situations where no one wants to be in. We have two SuperMax mills with 18 Controllers. One of them being down for a while due to cpu failure. Yesterday I did some cpu swapping to diagnose the problem but at some point something changed by itself on the good controller and now I have two machines down instead of one.
    It seems like a configuration issue and I don´t know how to put it back.. please see picture attached. Thanks for any help that you can provide.
    Feb 2015
    161
    Re: 915 SRAM PARITY - SISTEM ALARM
    That's not a configuration issue. That's a corrupt memory issue. While swapping, your good control's memory has been corrupted. Most likely by being disconnected from the battery for extended period. You need to reload a good set of parameters or backup.
    May 2014
    174
    Thank you SLT. I will proceed to do a backup download first thing in the morning.
    You have to clear all memory first then restore the parameters, part programs, PMC parameters, offsets, and what ever else you lost. To clear all memory you must press and hold RESET & DELETE while powering up. This will get you to the normal looking screens but all memory is cleared.
    May 2014
    174
    Quote Originally Posted by drdos View Post
    Hello. I'm now having trouble loading all files back to restore operation on the machine because I can't get the machine out of the MDI mode. For some reason, it won't respond to the operator's knob on the mode selector. I only gives me MDI mode.
    Apr 2009
    1379
    The MDI mode is default and you have to restore the parameters (NC and PMC) before mode changes are possible. Also, you can load/change parameters ONLY, while an alarm condition is present.
    May 2014
    174
    Dear friends, things are looking much better this moment. I was able to load all parameters back into the machine by following your inputs. Thank you all very much! when I left the plant, the machine was just about 95% operational, since all axis needed to be zero-ed. and since I am not so familiar with the operation of this particular machine, I had the operator trying to carry that last adjustment, but for some reason he hasn´t being able to get it done yet. All other aspects of the machine are working properly.
  1. Replies: 5
    Last Post: 04-20-2019, 02:31 PM
  2. 998 ROM parity alarm f81
    By shrineedi in forum Fanuc
    Last Post: 09-22-2014, 03:23 PM
  3. 601- PMC RAM PARITY ALARM
    By dilip2804 in forum Fanuc
    Last Post: 09-28-2013, 10:29 PM
  4. fanuc ot b 601 pmc ram parity alarm
    By cgccnc in forum CNC Machining Centers
    Last Post: 10-13-2012, 04:32 PM
  5. C-MOS PARITY ALARM, FANUC 3 M
    By JGPerry in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-09-2008, 12:47 PM
