Ok, short history.
1) bought water cooled Chinese spindle really cheap (380v 2.2kw)
2) tested without water, worked fine
3) tested water pump only
4) leaked... from almost everywhere
5) disassembled back side... no O-ring on one connection.. water went into.. everywhere, bearings and all.
6) need to disassemble spindle to dry, clean and replace bearings.
7) two M4 threats at the front to push spindle core out of the shell,
8) rear bearing won't move.. even broke 2 bolts trying to remove it.
I don't know what to do now... should I try heating it up a bit? should I just try to force it? please help....
