585,981 active members*
4,208 visitors online*
    Mar 2004
    dual purpose cnc router
    I am looking to build a medium sized router in the 24 x 36" or so range and want to be able to cut a variety of materials sucha as solid wood, particleboard, mdf, and aluminum (up to 1/2" thick). I now the wood and wood substates will not be a problem, but how about the aluminum cutting on the same machine? What design issues / changes do you recommend - short of 2 seperate machines?
    I am consudering using the data cut plans with slight madifications - anyone else use these?
    Thank all
    Dan
    I am doing almost the same thing as you. Here are my plans. 30x30 table.
    Proud owner of a Series II Bridgeport.
    Nov 2003
    299
    Re: dual purpose cnc router
    Originally posted by junkmail
    ...wood, particleboard, mdf, and aluminum (up to 1/2" thick). I now the wood and wood substates will not be a problem, but how about the aluminum cutting on the same machine? What design issues / changes do you recommend - short of 2 seperate machines?
    Dan
    Dan,
    The few major issues seem to be rigidity, mass, (which comes with a ridged machine) and type of bearings. You'll need a heavy ridged machine. The cutter bit will have a tendency to chatter as it cuts. Your machine needs to absorb that vibration. Don't skimp on the bearings. Use large Thompson supported rod or THK linear rails. Also you’ll need at least 30+ IPM to keep the cutter bit from loading. Of course coolant helps also.
    I can cut alum my machine. You may want to check it out.
    http://www.cnczone.com/forums/showth...&threadid=2249
    Search CNC Zone for “aluminum” or “milling” or “end bit”.
  1. Techno-Isel CNC router for sale?
    By Noah in forum Commercial CNC Wood Routers
    Last Post: 11-28-2008, 05:12 AM
  2. 2nd Generation CNC Router Design 32.5” X 14” X 6”
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 03-24-2005, 11:46 PM
  3. buscht's cnc router
    By buscht in forum DIY CNC Router Table Machines
    Last Post: 04-13-2004, 05:43 PM
  4. My first CNC router: 1.5 years building
    By hddjohns in forum DIY CNC Router Table Machines
    Last Post: 04-03-2004, 05:18 PM
  5. Budget CNC Router
    By Blackhawk in forum DIY CNC Router Table Machines
    Last Post: 02-22-2004, 02:19 AM
