585,735 active members*
4,846 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > 4axis rhinocam parallel finishing act weird
Results 1 to 6 of 6
    Apr 2017
    hi
    first picture shows how item must be,second picture shows the item after horizondal routing simulate and t third picture shows the problem, that the simulation cut off the object at the
    end to several pieces,something that sould not do.Any ideas why is that happening?
    I have make simulare item with out any problem,
    Any help would be greatful!
    Apr 2017
    Re: 4axis rhinocam parallel finishing act weird
    Please guys.
    Nobody have any simirar problem?
    Or knoing something about it?
    Apr 2004
    5734
    Have you asked Mecsoft's tech support about this issue? One really nice thing about RhinoCAM is that it comes with free telephone tech support. The technician can share your screen, show you where you went wrong, and how to fix it. You're in a different time zone, but it might be worthwhile to stay up late some night and call in during business hours in the Pacific Standard Time zone.
    Andrew Werby
    Website
    Mar 2010
    95
    How is toolpath looking? What tool do you using for finishing?
    I not sure it helps, but you may try:
    Go to Tools-Options
    In Document Properties go to Mesh and change Jagger&Faster to Smooth& Slower
    Recalculate TP
    Rerun Simulation
    May 2010
    11
    It would help if you posted the 3DM file.
    fcc
    1217
    Are all the normals the correct way round?
  1. HELP! parallel finishing Problem HELP!
    By Macguitar in forum Rhinocam
    Last Post: 03-25-2017, 05:19 PM
  2. Replies: 1
    Last Post: 02-29-2016, 01:26 AM
  3. Parallel Finishing Problem
    By kyle_vk in forum Rhinocam
    Last Post: 04-13-2015, 10:41 AM
  4. Weird circle G03 in Rhinocam Mach3 inch post
    By btsioles in forum Rhinocam
    Last Post: 10-22-2014, 09:56 PM
  5. Weird thread, taper into parallel.
    By inflateable in forum MetalWork Discussion
    Last Post: 06-09-2010, 03:15 PM
