585,668 active members*
4,269 visitors online*
IndustryArena Forum > CAM Software > SheetCam > Need post processor to use with sheet cam
    Apr 2017
    Hi guys new here and trying to get some help. So I got a different plasma table then what I had and I want to use sheetcam to make the gcodes since I'm familiar with sheetcam now. Problem is that I can't find the post for the Starfire controller that the baileigh table comes with and I know nothing about creating or editing posts. I found the post but it has to be installed on bobcad. I'll attach a gcode that I was able to get from the cnc controller parts library hopefully someone can help me with this. I've contacted sheetcam but haven't really got anywhere they will just give me a short reply once a day. If anyone could help me I would greatly appreciate it! Thanks
    Aug 2006
    44
    Re: Need post processor to use with sheet cam
    May be I can work on it to make a new post processor for your controller and sheetcam software.
    I need you email me a drawing file with the gcodes for that (from start to end ) that it works good on your machine .Tell me how you make that Gcodes.
    My email is [email protected]
    I am in Los Angeles ? Where are you located ?
    Apr 2017
    Thanks majami, the only gcode i have is the one on the pictures I posted, was a small part I cut from the controller parts library. I normally just use sheetcam to make the gcode. Thanks
    Quote Originally Posted by majami View Post
    Aug 2006
    44
    ok send me an email please and attached that file to see what I can do for you.
  1. Replies: 1
    Last Post: 01-02-2021, 11:05 PM
  2. wanted post processor from sheet cam to mach3 and mach 4 plasma
    By lkigam in forum Post Processor Files
    Last Post: 05-28-2016, 08:29 AM
  3. Replies: 2
    Last Post: 08-13-2014, 11:34 PM
  4. Sheet Cam Post Processor
    By CNCRob in forum Post Processor Files
    Last Post: 05-19-2005, 10:10 AM
