585,758 active members*
4,572 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > X and Y axis problem. DOES NOT MATCH THE ACTUAL LASER HEAD
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Mar 2017
    5
    Re: X and Y axis problem. DOES NOT MATCH THE ACTUAL LASER HEAD
    Quote Originally Posted by HRitcher View Post
    ¿lo solucionaste?
    Acceleration is too high, is missing steps, and sptes per mm may be worg because you reset controller.
  2. #22
    Jun 2020
    Hello I'm having the same problem... my x,y show 1000mm when I turn the machine on it slams into the side of the machine and doesn't stop.
  3. #23
    Mar 2017
    5
    Quote Originally Posted by GaGuy View Post
    See if end stops is working, if you want you can desativate home function in vendor settings on ruida controllers
  4. #24
    Jun 2010
    4256
    Well, for a start, your machine should be in eStop when you turn it on. You should put it in eStop before you turn it off.
    Cheers
    Roger
  5. #25
    i have the same idea as rui-sjm1
    our conpany use Ruida conrtrol system for our machine too
    The most likely situation you encounter is that the step parameter of the motor changes due to resetting the system
    You can find the software manual on the official website of Ruida, modify the parameters according to the manual, I hope it will help you
  6. #26
    Quote Originally Posted by car_bore View Post
    Here is a quick video of what I'm talking about.
    https://www.youtube.com/watch?v=tUXjW9yKHCs
    It wasn't making that noise before.
    did anyone ever get a fix for this problem and I'm just missing it? Are corrupt parameter files the culprit? I have exactly the same problem, but I am really kinda stuck because I inherited my laser and I have 0 files in the way of a backup. Also, the laser was new when I got it, but it had set for 6 years. Oddly everything is current tech in the way of controllers etc. (Ruida 6442G) It isn't a US machine (that I can tell) the scan tag led me to Orion Motors --- which is Omtech. So I probably have the equivalent of a 50W CO2 Omtech. I just can't find the definitive setup files etc. Any help is much appreciated!! Thanks
Page 2 of 2 12
  1. Laser head touch the left axis
    By medmouncef in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-11-2020, 03:54 PM
  2. Problem! - Laser Head going off table boundaries
    By quetzalstudio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-24-2017, 03:55 AM
  3. Decreasing the laser head transit time between actual cuts
    By vrc321 in forum Laser Control Software
    Last Post: 01-04-2017, 05:25 PM
  4. Build double head laser with motorized x axis on each head
    By amders in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-15-2015, 02:41 PM
  5. Laser Head won't move along Y axis...
    By jassk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-03-2012, 04:42 AM
