585,914 active members*
3,839 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco VM10i Adjust the clock on the control
    Jun 2006
    3
    Does anyone know how to set the clock on the control? It's the small one in the lower right corner of the control...Thank you in advance for helping.
    Jun 2008
    1104
    Re: Hurco VM10i Adjust the clock on the control
    Get the keyboard and press Ctrl then Esc.
    Tap the little green tab that appears on the left.
    Tap Control panel.
    Double tap date and time.
    Set the time like you would on your PC.
    Apply.
    Close windows.
    Tap left green tab again.
    Scroll to the bottom and tap Return to Winmax.
    Jun 2006
    3
    Quote Originally Posted by bloke View Post
    Tap Control panel.
    Apply.
    Close windows.
    Perfect!! Thank you so much! Worked like a charm.:cheers:
    Jun 2008
    1104
    Nifty!
  1. 4th axis on Hurco VM10i
    By johnhdsi in forum HURCO
    Last Post: 10-07-2014, 02:45 PM
  2. HURCO VM10i
    By 85burban in forum HURCO
    Last Post: 05-10-2014, 01:19 PM
  3. New VM10i Owner: Cheap touch probe options?
    By makerstoolworks in forum HURCO
    Last Post: 11-02-2013, 12:01 AM
  4. How do I adjust drives on Hurco BX
    By Jackal66 in forum HURCO
    Last Post: 06-14-2010, 03:39 PM
