585,743 active members*
5,056 visitors online*
Page 1 of 4 123
Results 1 to 20 of 74
    Mar 2014
    1131
    SIEG C6 Retrofit [Ongoing]
    Initially, I wanted to build an EG lathe from scratch. The drawing of the bed was finished, all parts was almost machined/gathered. Then, one day Tkamsker wrote his concerns about EG on a big machine, then I changed my mind and turned this way. Thanks @Tkamsker.
    I purchased this used SIEG C6 for a very low price. The machine had too many parts missing, like change gears, chuck jaws, chuck key, motor mounting parts, chip guard and chip base BUT the machine has a very low running time. It is almost new so, as I'm CNC converting it the missing parts are not important to finish the project.
    Here are some random photos.
    Attached Thumbnails Attached Thumbnails IMG_3832.JPG   IMG_3833.JPG   IMG_3834.JPG   IMG_3842.JPG
    Mar 2014
    1131
    Re: SIEG C6 Retrofit [Ongoing]
    More pics:
    Mar 2014
    1131
    The housing of the X axis ball nut is finished. I made it off tool steel.
    The threads inside the part is M20x1 and the threads on the top (for mounting the part) is M8x0.75.
    Mar 2014
    1131
    More pics
    Attached Thumbnails Attached Thumbnails IMG_3875.JPG   IMG_3876.JPG   IMG_3877.JPG   IMG_3879.JPG
    Apr 2009
    5516
    Nice work so far!
    Mar 2014
    1131
    Thank you.
    Sent from my GT-I9300 using Tapatalk
    Mar 2014
    1131
    Finished.
    May 2006
    84
    I've a C6 lathe and often thought about a CNC conversion.
    Watching with interest.
    Mar 2014
    1131
    Still working on the X.
    Attached Thumbnails Attached Thumbnails IMG_3887.JPG   IMG_3889.JPG   IMG_3890.JPG   IMG_3891.JPG
    Mar 2014
    1131
    And more...
    Mar 2014
    1131
    Just received the custom transformer for Z axis stepper.
    400va, 220vAC input, 60vAC output
    Nicely made.
    Mar 2014
    1131
    This is the first time I cut a key way with my lathe. It turned out good.
    Mar 2014
    1131
    Just received the 5v and 12v PSUs. 5v is for C11GS and C3, 12v is for the cooling fans.
    Mar 2014
    1131
    The timing belt (375xT5) of the Z axis.
    Mar 2014
    1131
    The Z axis is almost done. I just need to make some little work to get it finished.
    I cut a taper bush on my other lathe, for the big pulley but it isn't finished. The holes needs to be drilled and I'll cut a horizontal line. That's all.
    Mar 2014
    1131
    The tapered bush is finished.
    Mar 2014
    1131
    I bought a 2.2kw 3ph motor for the spindle. I'll use a 4kw Huanyang VFD to drive this motor.
    Attached Thumbnails Attached Thumbnails IMG_20170517_104710.jpg   IMG_20170517_104718.jpg
    Mar 2014
    1131
    The stock motor was 71 framed 550w. New motor is 90 frames and 2.2kw. I made an adapter for it.
    I have also made a pulley with 8mm keyway.
    Mar 2014
    1131
    850mm belt fits very well.
    Gear ratio is 1:2 so max spindle speed will be 150 RPM.
    Apr 2003
    354
    Quote Originally Posted by Azalin View Post
    I hope you intended to say 1500?
    You're doing a great job, I can't wait to it see it making parts!
    Milton in Tennessee ya'll!
Page 1 of 4 123
  1. Sieg SX3 6000rpm retrofit kit for mach3
    By slektning in forum Benchtop Machines
    Last Post: 01-28-2010, 06:08 AM
  2. Replies: 31
    Last Post: 11-27-2008, 06:55 AM
  3. SIEG X3 Budget DIY CNC Conversion Ongoing Project Summary
    By Ninhil in forum X3/SX3/G0619/G0463
    Last Post: 03-07-2007, 01:26 AM
  4. SIEG rotary table retrofit
    By ints99 in forum Syil Products
    Last Post: 12-17-2006, 06:11 AM
  5. CNC Retrofit for Sieg X2... KDN Tool?
    By Zippi in forum Benchtop Machines
    Last Post: 01-19-2006, 09:27 AM
