585,578 active members*
3,901 visitors online*
Thread: 2002 VF-3
    Jan 2014
    19
    2002 VF-3
    I have a VF3 coming that is wired for 480 V but I only have 240 3 phase in my building would it be better to rewire for 240 or get a transformer and step it up to 480 ..?
    Oct 2010
    171
    Re: 2002 VF-3
    I would think it would be easier to get a 220/480 transformer (and cheaper too). There are a number of 30kva transformers on eBay in the $500-$600 range. Might even find one cheaper with a bit of hunting. That should cover the VF-3, I believe.
    PM
    Mar 2014
    133
    Re: 2002 VF-3
    Haas sells a conversion kit,but precision is correct it maybe cheaper to find a step up transformer. I've heard of cases where some people will buy a step down transformer!but wire it backwards and you get the same result with achieving 480. Good luck to you.
  1. Looking at 2002 Vm1
    By vertcnc in forum HURCO
    Last Post: 06-06-2015, 06:05 AM
  2. so simple but...I cant do it (2002 surfcam)
    By Levtech in forum Surfcam
    Last Post: 11-26-2012, 08:13 PM
  3. Gibbscam 2002 help
    By missionrat in forum GibbsCAM
    Last Post: 10-24-2012, 02:56 PM
  4. AutoCAD 2002
    By ajl6549 in forum Autodesk
    Last Post: 08-02-2006, 06:35 PM
  5. ACAD 2002 issues????
    By DanFri in forum Autodesk
    Last Post: 07-02-2003, 07:16 PM
