585,662 active members*
3,076 visitors online*
    Feb 2008
    42
    AS3000 Software Install Woes
    Hi folks,
    Hoping someone here can help. Getting no love from Camsoft - only a nice fat bill for something I have yet to use.
    I have AS3000 software with a USB dongle. Install of the software went fine. I received a version ID file which I copied into the AS3000 folder.
    Plugged in the Rockey4 dongle. System did not recognize it, so I installed the proper Rockey4 drivers and all works well - system is recognizing Rockey4 USB and Rockey4 in device list. Dongle has solid green light, telling me everything is fine.
    Launch the software, only to receive a "Key not found" message. Tried different USB ports to no avail. Read through the manual, but there is no reference to this issue.
    If I am missing a procedure to get this (potential POS) software going, please let me know.
    Thanks a bunch,
    Mark
    Need a Supermax YCM-40 Mill manual? Download the PDF here (replace _ with .):
    http://www.istonline.ca/download/supermax-ycm-40.pdf
    Mar 2004
    1542
    Re: AS3000 Software Install Woes
    FWIW, you've covered all the bases I know. i'd call up Camsoft.
    Feb 2008
    42
    Thanks for the response. Kind of figured so.
    Anyone want to buy some CamSoft software? Cheap?
  1. AS3000 3D Level 5 CAD/CAM Software
    By skippyfix in forum CamSoft Products
    Last Post: 01-14-2018, 03:52 PM
  2. Software install V12
    By kenwoodhf in forum Dolphin CAD/CAM
    Last Post: 02-24-2016, 07:22 PM
  3. Software set up. CorelDraw, compatibility and Windows 8 woes
    By JArt3mis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-24-2014, 09:15 PM
  4. Is this software or machine issue? Lithophane woes.
    By Lithophantastic in forum PhotoVCarve and VCarve Pro
    Last Post: 10-30-2013, 01:25 PM
  5. AS3000 3D Level 5 CAD/CAM Software
    By skippyfix in forum Uncategorised CAM Discussion
    Last Post: 12-11-2008, 04:07 PM
