584,863 active members*
4,933 visitors online*
    Mar 2013
    13
    Y axis Ballscrew nuts screws NEED tightening
    My Y axis is sloppy and I found the screws that secure the ballscrew nut to the table are loose. I can get to the rear two that are right on the edge, Has anyone tightened all four?
    My mill is on a stand, on a pan, so I can not just go from underneath and gain access to them. I could punch a hole in the pan to access them but it appears that the "front" two are under/behind the ball screw itself.
    I am thinking to try and take the table off?
    Any clue on my best way to tackle this?
    Tony
    Mar 2013
    13
    Re: Y axis Ballscrew nuts screws NEED tightening
    I have the mounting screws for the block on my mill. From the photo you can see there are two, counter sunk screws under/behind the thinner steel mounting collar.
    #1 I have not been able to mover it, I think it is locktite'd
    #2 If it does move, the screws threads are most likely greater than the threads to the block. Im thinking it would just lock itself up.
    Any suggestion would be great
    Mar 2013
    13
    I think this assy video might be what Im looking for to Disassemble it and tighten the two screws
    https://youtu.be/1CWjAWrR6Nw
    This might help someone else down the road.
  1. Replacing the nuts on the gib screws on my X2
    By AVRnj in forum Benchtop Machines
    Last Post: 11-23-2013, 06:35 PM
  2. Tightening the end block on ebay ball screws?
    By Spinnetti in forum Uncategorised MetalWorking Machines
    Last Post: 03-11-2012, 05:58 PM
  3. Tightening ball screws and other wonders
    By Spinnetti in forum Linear and Rotary Motion
    Last Post: 11-12-2011, 01:17 AM
  4. Problems with ball screws and nuts.
    By jtriggs in forum Linear and Rotary Motion
    Last Post: 02-17-2008, 12:57 AM
