Please help regarding this issue
I have installed new lead screw in Y. Laser is giving error in 2mm. while before installation the error was 300 micron
Can anyone help which area is problematic ?
It sounds like the thread pitch of the new lead screw is not exactly the same as the old one. If not you will need to re-enter the "steps per" in your driver software to match the new screw pitch for that axis.
"Laser is giving error in 2mm. while before installation the error was 300 micron" please clarify what you mean by that. Is the error 2mm?
Over what distance? Is it repeating or accumulating?
Is the error proportional to the distance traveled, e.g. 1 mm for 700 mm?
Is the error the same for each direction?
Have any parameters changed? If so, which ones? Especially relating to DMR/CMR and scaling.
no parameters were changed actually
we have checked the mechanical assembly once again. found the chuck nuts were tight too much. machine was taking jerks at only one step about 2mm. 1 mm in both side . that's why the error was too big
Any ways thanks for your time. Will keep in touch.
