584,863 active members*
4,899 visitors online*
Results 1 to 8 of 8
    Apr 2009
    6
    NEED HELP!!! Fanuc OM AXIS INTERLOCK
    Recently I purchase a Supermax 1 Rebel, Changing the parameters for use a DNC software accidentally turn off the machine before restore the PWE to 0. When I restart the machine I cant move any axis and it show a massage " axis interlock". I need help! Thanks Folks!!!
    Apr 2017
    28
    Re: Fanuc OM AXIS INTERLOCK
    Hold "P" key and "CANCEL" at the same time, power on the control, this should remove the alarm and allow you to move the axes away from OT switch.
    Apr 2009
    6
    Cincyice58, Thanks a lot!!! The cnc is moving again!!!
    Apr 2017
    28
    great to here
    May 2016
    26
    I have a supermax mill just purchased it. It came without parameters, I could read only scrambled letters and numbers. I reentered all parameters from the data sheet found.
    I have an alarm so far "operator message" 2000.
    Any ideas...
    Quote Originally Posted by zagpaz View Post
    Any ideas...
    I now have this machine. Did you ever figure it out. Im in Post Falls
    Jan 2022
    7
    Quote Originally Posted by AndrewHarrison View Post
    TENGO EL MISMO PRBLEMA NO ENCONTARSTE SOLUCION
    Apr 2009
    6
    En aquel momento se encontro que la presion de aire que matiene el carrusel de herraminetas arriba no era suficiente , el control fanuc detectaba que el carrusel de herramineta estaba fuera de posicion.
  1. Fanuc OM w/ no. 2000 axis interlock alarm
    By bikebasher in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-10-2022, 05:38 PM
  2. VTC 20c Error 128 outside interlock axis HELP PLEASE!
    By AK2015 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-07-2015, 08:51 AM
  3. alarm 128 outside interlock b axis
    By mikegmoore in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-22-2014, 12:18 PM
  4. mazak vtc-16b 128 axis interlock
    By krueg64 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-17-2014, 06:20 PM
  5. Safety interlock Fanuc 10M?
    By Tolyatti in forum Fanuc
    Last Post: 12-02-2011, 08:03 PM
