I have a travel issue on one axis of a gantry with a 320 gecko. I can tune the travel distance in one direction to be spot on. When commanded the same distance in the opposite direction there is a gain of about a half inch in 36 inches.This remains constant so that there is additional gain every command. I have tried three different encoders and three different gecko drives and get the same problem with all. The Gecko thinks it is traveling correctly as is does not trip out when driving the incorrect distance. This is run by mach 3. The DRO shows the correct commanded travel. If I reinstall the original stepper motor with the same commands the travel is correct in both directions. The current encoder is a 600ppr incremental. The other two were an optical and a magnetic. I called gecko tech support and they suggested mechanical slip issues. I have checked that out and find no problem with slippage, and it is disproved by the stepper traveling correctly. I need more power than the stepper can deliver. Is there a test method I can employ to find the culprit?
Thanks for any suggestions.
Scott
