Hi guys,
Ive watched various videos and tutorials now on setting the home using Mach 3 but there seems to be an issue. Infact i think there is more than one issue. Using the Keyboard Cursor Keys the X,Y and Z axis doesnt traverse smoothly. When i press a cursor to traverse the x axis the spindle moves either in the + or - direction for a few seconds before stopping. The motor seems to jam or buzz louder at this point but if i release the cursor key and depress it shortly thereafter then travel resumes for another 2 or 3 seconds before the behaviour repeats itself. This behaviour is present on all axis. Now however on the Y axis which has 2 ball screws the two mottors dont jam or trip out at the same time causing the carrage to twist out of alighnment as one motor is still driving and the other is stopped ! I am sure if i had time I could get to the bottom of this if it was my own machine but ive been called into fix this for friends and they bought the machine second hand so I dont know what twiddling has been done, what faults may be present etc but i think this is a software issue as its present on all axis. Now to further confuse matters if I press REF ALL HOME then all axis traverse smoothly ! I know im missing something basic but I need pointed in the right direction and preferabally a breakdown of what i need to check, or edit in the config to ensure this works. Im not an expert with electronics so if its a fault on the control board I dont know how i could diagnose this. Can anyone help ? Thanks !
