585,930 active members*
3,934 visitors online*
IndustryArena Forum > Additive Manufacturing / 3D Printers and 3D Scanners > 3D Printing / Scanning Software and Hardware > The ultimate accessory for your 3D printer: a solid state laser cutter attachment.
    Exclamation The ultimate accessory for your 3D printer: a solid state laser cutter attachment.
    Originally developed for a NASA project, we present a powerful diode laser that can convert your 3D printer or CNC router into a powerful laser engraving / cutting machine.
    Attachment 359474
     In 2014 we created the 2.1W L-Cheapo laser.
     In the middle of 2015 we presented the 3.5W L-Cheapo Mk3.
     In 2016 we forged ahead with the L-Cheapo Mk4.
     Now, we introduce the Mk5. 8 watts of continuous output allows for working on any material that can be engraved or cut by a CO2 laser.
    Meet the L-Cheapo MK5, with a continuous output of 8000mW – continuous over hours, and measured at the workpiece.
    Attachment 359476
    Key features:
     Optimized for continuous output: beware competitors who only state their peak output! We promise 8000mW and deliver 8000mW.
     24/7 full tech support
     Easy to install and remove for quick tool swapping.
     Compatible with most 3D printers and CNC mills
     Can cut and engrave many materials including: wood, plywood, fabric, felt, acrylic, ABS, PLA, cardboard, hardboard. Can be used for PCB and aluminum etching with the appropriate chemicals.
     Made in the USA.
    This power is enough to cut 6 mm ¼’’ of wood and plywood.
    Attachment 359478
    Create and engraving nice images on plastic and acrylic.
    Attachment 359480
    You can engrave on glass and etch aluminum or copper.
    Attachment 359482
    With MK4 L-Cheapo 5.6W laser you can turn your creativity into reality. Start laser cutting and laser engraving with ease as never before.
    Attachment 359484
    All models within the L-Cheapo line can be easily installed on any 3D printer or CNC machine. If you already have a laser engraver, the control system allows for rapid upgrading of your laser by swapping the diode block.
    Does not require additional cooling or optical trimming; runs on 12V to 24V inclusive, allowing you to use a ATX power supply or laptop power brick if you so choose.
    Engrave and cut images from JPEG, EPS, gcode, NC files and more using the unified plugins.
    Attachment 359486
     For a limited time, get your 8W MK5 L-Cheapo laser today for 495$ 475$ only.
     Special offer on 3.5W MK3 L-Cheapo laser for 295$ 279$ only
    Use promo code (“sale42” to get a discount)
    Learn more on Endurance L-Cheapo 5.6W diode laser
    endurance_robots Guest
    use promo code "industryarena 20%" to get 20% off on http://endurancelasers.com/
  1. Laser cutter accessory – How to create a 3D logo model
    By Endurancerobots in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-20-2015, 07:16 AM
  2. Replies: 0
    Last Post: 01-19-2015, 11:44 PM
  3. Cutting textile with solid state laser?
    By Rokas in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-03-2014, 12:24 PM
