585,760 active members*
4,037 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller Cards > 5 SERVOS 1 VFD SPINDLE BREAKOUT BOARD 6 AXIZ
    Feb 2016
    50
    HELLO,
    I HAVE A X, DUAL Y, Z, SERVO SPINDLE, AND VFD SPINDLE SETTING UP. THE SPINDLES WILL BE CHANGED OVER AS NEEDED.
    I PLAN TO USE PULSE/DIRECTION FOR THE SERVOS INCLUDING THE SERVO SPINDLE(FOR TAPPING). THE VFD SPINDLE WILL BE FOR HIGH SPEED WORK AND PLAN TO USE THE ANALOG 0-10V SPEED CONTROL. I WILL USE MACH3 AND A DESKTOP COMPUTER WITH PARALLEL, USB, AND ETHERNET.
    I HAVE READ ALOT OVER BOBS AND SEEN TROUBLES WITH CONSUMERS.
    MY QUESTIONS ARE:
    I SHOULD USE DUAL LIMITS FOR MY Y GANTRY? THAT WOULD BE 8 LIMITS, PROBE, AND ONE ESTOP.
    WHAT BREAKOUT BOARD WOULD WORK FOR ME WITH LEAST TROUBLES? 5X PULSE/DIRECTION, 1X ANALOG 0-10V.
    Apr 2016
    43
    Re: 5 SERVOS 1 VFD SPINDLE BREAKOUT BOARD 6 AXIZ
    MB2 from CNC Room.
  1. questions regarding a good motion or breakout board for Servos and Mach3
    By want-to-be-cnc in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2016, 08:56 PM
  2. Connecting spindle to breakout board
    By waterrat in forum Spindles / VFD
    Last Post: 11-01-2014, 11:58 PM
  3. Replies: 27
    Last Post: 03-10-2014, 08:02 PM
  4. c11 breakout board spindle
    By dougputt in forum Machines running Mach Software
    Last Post: 08-07-2011, 04:13 AM
  5. breakout board with spindle speed control
    By 6bx in forum CNC Machine Related Electronics
    Last Post: 02-19-2009, 08:35 PM
