585,975 active members*
4,566 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > HUANYANG INVERTER AND SPINDLE SET UP
    Apr 2017
    Need help. I have a Huanyang HY01D511B 110V 1.5 KW, 800W, 5A, 400 HZ, 24000 RPM water cooled spindle. This is not like those posted in other blogs/threads. I did not wire this. It came wired with 3 prong plug 110v/1.5kw from inverter to wall and then 4 prong screw fitting to spindle.
    I enter the following and press run and error code E.O.C.A. comes up and spindle just clicks.
    PD01 =0
    PD02 =0
    PD03 =400
    PD04 =400
    PD05 =400
    PD07 =20
    PD08 =220 (120 if you have 120v VFD on some threads I've tried both and 110)
    PD09 =15
    PD10 =8
    PD11= 120
    PD13= 8 (Only use if factory resetting)
    PD14= 12
    PD15= 12
    PD141= 220 (120,... SAME AS PD08)
    PD142= Motor max amps = 5Amps I'm guessing and have put that in each time
    PD143= 2 (Its a single phase not triple, so guessing its 2 poles- can't find anything stating different)
    PD144= 3000 (400HZ=24,000 so 50HZ=3000) Saw that on another thread.
    PD70= 0
    PD72=400
    PD73= 120
    That is all I have entered in the inverter. I have reset to factory settings twice and entered each one and double checked. Always the same answer--E.O.C.A and can't operate my new CNC. Help... please.
    15362
    Re: HUANYANG INVERTER AND SPINDLE SET UP
    Quote Originally Posted by MTMOOSE797 View Post
    PD01 =0
    PD02 =0
    PD03 =400
    PD04 =400
    PD05 =400
    PD07 =20
    PD09 =15
    PD10 =8
    PD11= 120
    PD14= 12
    PD15= 12
    PD70= 0
    PD72=400
    PD73= 120
    The VFD Drive is 3Ph output not single Phase , the only part that is single Phase is the input power, ( 50Hz=3000 this is incorrect and has nothing to do with your spindle or your VFD settings )
    The parameter settings are correct, depending on what the spindle motor voltage is, if it is 110v then the PD08 and PD041 must be set at the spindle Voltage
    E.O.C.A. is not a good fault to see, as it could mean that the spindle is damaged, check the spindle windings with your meter
    Pin 1-2
    2-3
    3-1
    and 4 to Ground or spindle body
    Also post a photo of the input power wiring
    Mactec54
  1. Huanyang 1.5KW Inverter / Spindle Question
    By bkp08817 in forum Phase Converters
    Last Post: 07-19-2013, 06:24 PM
  2. 220V in to Huanyang Inverter
    By Jerry In Maine in forum DIY CNC Router Table Machines
    Last Post: 04-13-2013, 01:43 AM
  3. Huanyang Inverter Problem
    By icanoe in forum Community Club House
    Last Post: 03-15-2013, 01:35 PM
  4. huanyang inverter burn
    By edgas10 in forum CNC Machine Related Electronics
    Last Post: 07-02-2012, 06:42 PM
  5. Huanyang inverter
    By mdileva in forum Phase Converters
    Last Post: 06-18-2012, 03:24 PM
