585,971 active members*
4,156 visitors online*
IndustryArena Forum > CAM Software > Alphacam > alphacam to mach3 issue
    Mar 2017
    Hi everyone, i recently bought myself a home made cnc router. I use alphacam at work and so wanted to keep using that, iv looked around the forum and found the post for it however on cutting a sheet yesterday i have found a issue!!!
    I know it will be something in the post that needs changing but i have absolutely no idea what it is
    if you have a look at the photo it has just gone over and done a random cut on the left. I have added the post that i have got from the forum aswell. any help would be great :cheers:
    Chris
    Apr 2015
    327
    Re: alphacam to mach3 issue
    post look ok (some simple things, but nothing what can cause problem with a rapid). . I do not think that problem is with a post. Can u upload also alpahacam file?
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
  1. Alphacam settings issue.help?
    By DellaRosso in forum Alphacam
    Last Post: 03-13-2015, 09:09 AM
  2. Post processor Mach3 / Alphacam
    By ibccnc in forum Post Processor Files
    Last Post: 11-29-2014, 03:02 PM
  3. AlphaCAM v5 and Anderson Stratos Issue
    By mrneelix in forum Uncategorised CAM Discussion
    Last Post: 01-15-2012, 01:44 PM
  4. Alphacam Router Z value issue
    By celtic1967 in forum Mastercam
    Last Post: 09-18-2011, 05:51 PM
  5. postprocessor alphacam for mach3 (turning)
    By tantan in forum Screen Layouts, Post Processors & Misc
    Last Post: 04-15-2008, 07:42 PM
