585,894 active members*
4,698 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Building 3 axis STEP/DIR to +/- 10V Analog servo controller
    Apr 2017
    Hello community!
    I recently acquired Gene Machines OmniGrid 100 microarrayer similar to this http://www.cnczone.com/forums/diy-cn...ml#post1048296
    I got ball screw Parker linear stages with hall home and limit switches, gantry and control module. Control module has power supplies and Parker OEM670T drives, taking +/- 10V.
    The system was missing the computer based servo controller.
    I was unable to find anything affordably to buy. The cheapest option is CSMIO/IP-A| 6-axis Motion Controller, which cost 600 euros. I bought the whole machine for $250!
    I decided to build my own controller.
    I initially created Atmega2560 based 3 axis servo controller and successfully ran it as 3D printer and LinuxCNC router, but it couldn't handle 1000 steps/rot encoders at high speeds.
    I am currently working on STM32F4 based 3 axis servo controller, and thinking about making it into an inexpensive product ~$100 for 3 axis controller.
    The goal is to make it standalone, with LCD screen, button control, and PID autotune.
    I would like to get some feedback from community about this idea. Trying to create a simple minimum viable product.
    It would be great if I can find somebody at San Antonio, TX who will be willing to test it for CNC retrofit or custom project.
    May 2017
    8
    Re: Building 3 axis STEP/DIR to +/- 10V Analog servo controller
    Hello.... this sounds intriguing.... how far are you along with this?
    Sent from my iPad using Tapatalk
    Apr 2017
    Quote Originally Posted by padstar View Post
    Hello,
    The PID controller is working on all 3 axis. Currently working on PWM output filtering and optoisolation.
    I decided to switch to smaller monochrome OLED screen, since large color LCD screen take too much time to output info.
    Next step, would be to implement an PID autotune algorithm.
    I will update here. This is my third job, so things are not moving as fast as I would like to.
  1. step/dir vs analog / servo encoder vs output
    By alan_3301 in forum Servo Motors / Drives
    Last Post: 08-20-2014, 07:50 PM
  2. UHU Servo controller with +/-10 Volt analog output
    By visky in forum News Announcements
    Last Post: 10-28-2012, 04:06 PM
  3. UHU Servo controller with +/-10 Volt analog output
    By visky in forum UHU Servo Controllers
    Last Post: 08-16-2012, 05:04 PM
  4. step by step instruction for building controller
    By avengine in forum Community Club House
    Last Post: 04-21-2006, 01:24 PM
  5. Pixie Step/Dir to Analog Servo Controllers
    By KTP in forum News Announcements
    Last Post: 03-06-2006, 05:12 PM
