585,733 active members*
4,983 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > Machining a curved stair tread
    Apr 2017
    I've two stairs that are a bit odd in shape. I did a quick 3D draw for them:
    There used to be carpet on them but we want to replace it with hardwood... I was wondering if somebody can help guide me through the process to machine these treads?
    I use Fusion 360 to model and CAM.. I've access to a shopbot desktop and have used it a few times already.. but I'm not an expert...
    I've left over hardwood interlocking panels from when I did the floor...
    What I've in mind right now is:
    1) Get the right measurements, the above is just an approximation... and transfer that into a model. Any ideas for how to accurately transfer the curve?
    2) I interlock enough panels to form a continuous panel big enough to cover the curve maybe staple them into a flat MDF or something
    3) Cut both treads from the same panel because if it's big enough for the lower step, I should have enough?
    4) Figure out what to do with the nose? maybe get a couple of these: http://ljsmith.com/assets/files/pdf/...ndingTread.pdf if you think it's a good idea..
    ideas?
    Apr 2017
    Re: Machining a curved stair tread
    Quote Originally Posted by ProfH View Post
    ideas?
    Is this the right place to post such a question? Feel free to suggest something different if not
  1. Stair Stepping on Y Axis
    By jamiemcshan in forum DIY CNC Router Table Machines
    Last Post: 08-08-2016, 07:01 PM
  2. STAIR CASE TORSION BOX
    By zachf in forum BobCad-Cam
    Last Post: 11-27-2012, 09:56 PM
  3. Wanted CNC Router for stair stringers and curved fascia board
    By lderk5 in forum Want To Buy...Need help!
    Last Post: 09-14-2012, 07:22 AM
  4. Cutting Stair Stringers
    By pirateducky in forum Torchmate
    Last Post: 03-02-2012, 04:14 PM
  5. stair template
    By mdred68 in forum WoodWorking Topics
    Last Post: 08-05-2007, 05:03 PM
