585,763 active members*
4,141 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > videos & stuff from the big www
Page 1 of 2 12
Results 1 to 20 of 34
    Jun 2015
    4154
    i just received this video : is about achieving better grip with less contact for 5 axis machining, based on parts prestamping
    kindly !
    https://www.youtube.com/watch?v=CmM9...7Chatter_April
    Jun 2015
    4154
    Re: sharing videos
    this one is about somekind of an upside down vertical lathe
    i guess that such a cnc is ok for small parts that dont require a strong spindle, and also are required to be machined one by one
    maybe someone will find this machine usefull ...
    https://www.youtube.com/watch?v=2tRi...7Chatter_April
    Jun 2015
    4154
    Re: sharing videos
    superimposed machining : i guess is good for parts that have a nice stable setup, otherwise the cnc will be stopped twice often, because for corection on left or right side of the turret
    also i think that the 2nd spindle will be subject to more inertia, since its movement is not relative to the chasis, thus it is not relative to a fix point, but to the turret, that is also moving
    https://www.youtube.com/watch?v=59ZpU6CmKzU
    https://www.youtube.com/watch?v=7Hy7dOscJmA
    Jun 2015
    4154
    Re: videos & stuff from the big www
    Jun 2015
    4154
    Jun 2015
    4154
    Jun 2015
    4154
    hello, please, what is the magic trick from 3:40 ? is it a simple operator intevention, thus dragging the part out by hand?
    https://www.youtube.com/watch?v=De1-8RwkY4E
    Jun 2015
    4154
    Quote Originally Posted by deadlykitten View Post
    air unloader
    http://www.lns-america.com/catalog-E...oader/Blazeair
    ... pls find attached
    Attached Thumbnails Attached Thumbnails LNS Blaze Air Brochure.pdf
    Jun 2015
    4154
    hello, does anyone knows what is the tool from 6:40 ? it is a pretty versatile excentric attachement
    unfortunately, i dont have more infos about it ...
    https://www.youtube.com/watch?v=NwOtZnjqKGA
    Jun 2015
    4154
    here you go
    D'ANDREA S.p.A
    https://www.youtube.com/watch?time_continue=36&v=3eLIvaQt16s
    Aug 2011
    419
    "Imagination is more important than knowledge."
    Aug 2011
    419
    Jun 2015
    4154
    hello all pls is there an alternative for Haas P-cool ( 3:00 in this video ) for Okuma ?
    i do it the right way : opening the doors + adjusting nozzles position by hand + getting a bit wet
    https://www.youtube.com/watch?v=TX6sEswLjRc
    Jun 2015
    4154
    feeding the turret 360, by hand wheel good to check clearances ...
    https://www.youtube.com/watch?v=E1Mn2F7bCf4
    Apr 2014
    18
    Hi deadly, this is the alternative for any machine. SPIDERCOOL | SPIDERCOOL – A Machining Necessity
    Jun 2015
    4154
    arc threading : so far i don't know a case where this function would be required
    so why only turn a sphere, when you could also thread it ?
    *when machining a sphere, to improve spherical characteristics near the top, use lost motion comp settings, so to manage backlash
    https://www.youtube.com/watch?v=O3twPF4b850
    Jun 2015
    4154
    Quote Originally Posted by OKUMA85 View Post
    Hi deadly, this is the alternative for any machine SPIDERCOOL | SPIDERCOOL – A Machining Necessity
    hy / thank you very much please, somehow do you know an alternative in Europe ?
    you saved me : we were buying a haas cnc only for that P-cool, and when i saw your reply, we canceled the contract
    do you know what music is at 2:45 in 1st movie of this post ?
    spidercool is so cool : do you know that spidercool has a president ? yes, el presidente @ 2nd movie in this post
    there are also customer confessions : if you are looking at those movies in low quality, it seems a bit spooky / also you can notice how the camera is slowly zooming in ( this effect is comonly used in trash news, that are all over the TV these days )
    also i like how serious are those guys when describing how spidercool changed their lives my god, there is so much stress in this world
    guy @ 2:10 seems nice
    https://www.youtube.com/watch?time_c...&v=40c8agNG4XQ
    https://www.youtube.com/watch?v=XLgC4TDAR6I
    Jun 2015
    4154
    try Japan : Programmable coolant systems: Wavy Nozzle - MinebeaMitsumi
    Apr 2014
    18
    This is European alternative
    https://www.coolant-hose.com/variojet-vj14/
    Jun 2015
    4154
    take a break / watch a movie : valerian and the city of a thousand planets
    olaaaaaa everyone this thing will ( almost ) remove ( all* ) the oil layer that is above the coolant
    cleaning a coolant tank is decided by a few factors :
    ... 1) a lot of big chips inside the coolant tank ( chips may fall inside the tank when using a conveyor, or when removing the chips with a shovel, etc )
    ... 2) small chips ( like dust, etc, microparticles ) inside the tank
    ... 3) too much lube oil
    ... 4,5,6,7,8,9, ... etc
    so you dont have to worry about the 3rd factor anymore
    of course, there are also oil-skimmers, but this product is much better / kindly
    *all = 99.99954796349875643 %
    https://www.youtube.com/watch?v=i0R1JoR5TUY
Page 1 of 2 12
  1. chuck grip force
    By deadlykitten in forum Okuma
    Last Post: 10-06-2016, 05:07 PM
  2. Looking to sell my grip CNC setup/business
    By Us ill in forum Chinese Machines
    Last Post: 06-28-2014, 05:12 PM
  3. mitee grip question
    By wild01 in forum MetalWork Discussion
    Last Post: 05-11-2014, 03:36 AM
  4. How to cut skateboard grip tape
    By eatabean in forum Community Club House
    Last Post: 10-14-2013, 06:38 PM
  5. Esprit Re-Grip
    By cbr_speedster in forum Esprit
    Last Post: 05-14-2011, 12:55 PM
