585,932 active members*
3,534 visitors online*
Results 1 to 15 of 15
    PathPilot™ v1.9.11 Now Available
    FYI
    https://www.tormach.com/pathpilot-documentation.html
    In This Version-
    Please be sure to read the release notes for a complete summary of all enhancements and bug fixes.
    Enhancements:
    • In rare situations, updates could fail to apply correctly if the PathPilot controller becomes unresponsive
      while updating. The controller is then non-operational, and displays an error message stating it failed
      to generate an INI file.
      The update process is now more reliable due to several enhancements:
      - Improved safety of file system disk cache settings.
      - Automatic controller reboot after applying an update.
      -Automatic creation of a backup file containing PathPilot settings and tool tables prior to applying
      an update — the backup file is named PathPilotBackupSettings-Year-Month-Day.zip and stored on
      the USB drive that contains the update file.
      In the event of a future hardware failure that requires you to use the PathPilot recovery DVD, use
      the backup file to restore your PathPilot settings and tool tables: in the PathPilot interface, from
      the Main tab, type ADMIN SETTINGS RESTORE in the MDI field and click ENTER on your keyboard.
      For more information, refer to the machine Operator Manual.
    For release notes and more information on this version as well as issue tracking and reporting visit the PathPilot Software Center.
    Nov 2007
    2151
    Re: PathPilot™ v1.9.11 Now Available
    I just installed v1.9.10 3 days ago
    Jul 2015
    81
    I just down loaded v10 but did not install it yet.
    Might wait and see what happens before updating now.
    Sep 2005
    540
    I installed version 10 yesterday and everything worked as expected. My control is homebuilt with an ASUS board and not a Tormach supplied PC if that matters.
    Robert
    Sep 2009
    624
    Quote Originally Posted by oneineight View Post
    I have adopted a policy of not installing for a week or so unless I have nothing scheduled.
    There have been three instances of fast updates over the past 18 months, the current v10 to v11 release, and an earlier one (1.9.4) that went to a "b" version almost immediately. 1.9.6 did the same thing, took a couple weeks though. I'm happy to see fixes issued quickly; I wish pre-release testing had more resources (and understand the problem there as well - "shoot the engineer" applies to software development too).
    Aug 2015
    368
    I don't update for a week or so either generally, I never did 910, just installed 911, after making a back-up file, and checking the back-up file. It installed and works great for me so far...
    STILL NO FILE MANAGEMENT!! This really pisses me off, can't copy and paste, drag and drop, that went away like a year ago, I have a huge mess of files because I can't move ops into folders, wish this was fixed...
    Sent from my SM-G900V using Tapatalk
    Apr 2013
    1788
    If you connect to the Samba share from a networked PC you can drag/drop/delete with ease.
    Aug 2015
    368
    Quote Originally Posted by kstrauss View Post
    I can do everything except dragging or copying from the list in pp into folders in pp. Lack of that ability leaves a huge messy list of ops that can't be organized into folders.
    Apr 2013
    1788
    Do you mean that using the Samba share you can do everything except dragging into folders or without using Samba you can do everything except dragging into folders?
    Aug 2015
    368
    Without Simba Share, I haven't used that, just within PP, no copy/paste.
    Dec 2016
    37
    If you insert a USB stick you can move the files back and forth into different folders. Not the nicest way to do but at least it can be tidied up.
    Feb 2007
    1538
    Running V1.9.11 now and so far all is well. Keen
    Nov 2012
    104
    anyone else having the "CANNOT USE AXIS VALUES WITHOUT G CODES THAT USES THEM" error when using MDI commands?
    i updated to v1.9.11 hoping it would fix that but nope, still having the same issue.
    thanks guys
    Apr 2013
    1788
    What MDI command did you enter?
    Nov 2012
    104
    when i first start up the machine and use MDI i get this error, because the machine needs to know the G-code, so instead of typing in X0 Y0, i need to type in G00 X0 Y0 as an example otherwise the machine doesnt know what speed to move at because a program hasnt been run, because after u run a program and type in just X0 Y0 itll default to the last previous run G code speed.
    so either run a dummy program or just use G00 X0 Y0 for the first entry and then X0 Y0 there after
    thanks guys
    - - - Updated - - -
    just using basic X0 Y0 commands, X.2 Y-.2 for edge finder etc etc etc
  1. PathPilot
    By SoCalPlaneDoc in forum Tormach PathPilot™
    Last Post: 03-22-2017, 10:18 AM
  2. PathPilot v1.9.8
    By kstrauss in forum Tormach PathPilot™
    Last Post: 02-01-2017, 09:50 PM
  3. Pathpilot G95 issue
    By tko829 in forum Tormach PathPilot™
    Last Post: 10-02-2016, 04:49 AM
  4. PathPilot toolpath?
    By kdupreez in forum Tormach PathPilot™
    Last Post: 02-11-2016, 09:15 PM
  5. PathPilot V1.6
    By adamboon in forum Tormach PathPilot™
    Last Post: 03-26-2015, 12:33 PM
