585,931 active members*
3,702 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Dolphin V13 - Tormach PathPilot Post Processor
    Aug 2016
    9
    Anyone have a Post Processor for Dolphin V13 that has been modified for PathPilot? I am using the M_F6MB and everything seems to work okay except for tool offsets and going to tool change position prior to tool change so I have to do separate programs for each tool. Yea, a pain. Any help would be appreciated Thanks.
    Jul 2010
    180
    Re: Dolphin V13 - Tormach PathPilot Post Processor
    As pathpilot is just a hacked version of Linuxcnc, I would be using the that processor!
    There is no reason why Dolphin or yourself can't change the post so on the fly tool changes work.
    Aug 2016
    9
    Thanks much for the info and advise but I don't have a maintenance contract with Dolphin and am really not interested in reinventing the wheel. Just thinking maybe someone else had run into this problem and could actually provide a solution.
    Feb 2007
    412
    Hello
    I have attached a zip file that contains 2 versions of the Tormach post, IJs absolute or Incremental - use the one that suites your PathPilot configuration.
    You will need to unzip the contents to your Documents folder and then use this method to import them.........
    IMPORTING POSTS
    Having received a new or modified post processor, you will need to import it.
    To do this double click the PartMaster Post Processor icon from your desktop, from the top toolbar choose Import
    and browse to the folder where the new/modified post processor was saved.
    When the file has been imported you will see the contents in the display area, next choose Compile from the top toolbar to create the .ppx file.
    The new post-processor is now ready for use. Close the post-processor by using File > Exit.
    When you next run DCAM or DWES the post processor will appear in the drop down list along with all original posts.
    Best Regards
    Andre
  1. CamWorks Post Processor for tormach pathpilot
    By ccsgtech in forum CamWorks
    Last Post: 01-25-2016, 08:43 PM
  2. Replies: 10
    Last Post: 08-02-2015, 04:13 PM
  3. Replies: 1
    Last Post: 04-09-2013, 04:25 PM
  4. Dolphin partmaster mach 3 post processor
    By Goesman in forum Screen Layouts, Post Processors & Misc
    Last Post: 02-06-2009, 10:15 PM
  5. Dolphin post processor help please
    By ImanCarrot in forum Dolphin CAD/CAM
    Last Post: 02-06-2007, 04:27 PM
