585,717 active members*
3,917 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 4 AXIS NOT OUTPUTTING DIFFERENT ANGLE
    Sep 2010
    86
    Im machining this part on a 4 axis machine.
    How would I tell Mastercam to output the machining of the enclosed area ( red) with the same G54 but at a different angle (ie 30 degre) , kind of indexing. I did create a plane at that angle and did the machining ( Contour). The simulation shows the tool at an angle, but the G codes output are on A0 angle.
    Thank you
    Apr 2003
    3578
    Re: 4 AXIS NOT OUTPUTTING DIFFERENT ANGLE
    You need to move that angle or CS planes you made to the center of rotation for starters. then only set the Cplnae and the TPlane on that operation and the WCS should stay at the WCS that was setup for center of rotation.
    Cadcam
  1. Replies: 2
    Last Post: 11-21-2015, 01:15 AM
  2. cross axis angle correction, how?
    By amirh in forum LinuxCNC (formerly EMC2)
    Last Post: 03-19-2013, 01:39 PM
  3. A Axis Mach3 Angle Calibration
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 09-19-2010, 01:58 AM
  4. angle position axis
    By bfservice in forum Fanuc
    Last Post: 09-29-2008, 03:51 AM
  5. 4 degree angle axis for toolpath?
    By Rich05 in forum Mastercam
    Last Post: 06-18-2008, 05:02 PM
