586,000 active members*
4,834 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Conquest T51 problem threading.
    Sep 2008
    22
    We have a lathe hardinge model CS-51 conquest snake T51, Control fanuc 18T.
    The problem is the following.
    When we run some cycle. (G71, G72, etc.) the machine works perfectly.
    But when running the thread cycle (G76), the machine runs the program, but when it starts the thread cycle.
    The Z and X axes do not move, the spindle rotates normally, there are no alarms.
    The program has been proven, previously worked everything perfect.
    The winch is equipped with C-Axis. We have never managed to make it work.
    A technician was trying to run the C-Axis.
    He says he has returned to his normal state. When threading worked but we did not really believe it.
    You could help us with some information, in which direction we can go, to solve this problem.
    thanks
    May 2016
    526
    Re: Conquest T51 problem threading.
    Check your spindle encoder the parameter it looks at is in the manual
  1. Conquest 42 turret problem
    By drt101 in forum Bridgeport / Hardinge Mills
    Last Post: 06-18-2020, 06:13 PM
  2. conquest 42 jogging problem
    By thach47 in forum Hardinge Lathes
    Last Post: 08-24-2016, 05:36 PM
  3. Conquest 42 turret problem
    By bdrysdale in forum Hardinge Lathes
    Last Post: 01-05-2016, 05:46 PM
  4. Hardinge Conquest 42 G76 Threading Problem
    By Phoenix123 in forum Hardinge Lathes
    Last Post: 06-21-2014, 08:20 AM
  5. hardinge conquest 51 problem
    By bassmastrbw96 in forum Hardinge Lathes
    Last Post: 09-05-2008, 02:39 AM
