585,974 active members*
4,191 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CNC (Mill / Lathe) Control Software (NC) > "Runtime error 9 - subscript out of range" on Techno CNC interface
    Mar 2007
    Hi, i'm new here, and i was milling today when i encountered "runtime error 9 - subscript out of range". I am cutting 3/4" mdf, and pathed on mastercam X. The mastercam file previews perfectly on mastercam, and the exported NC files preview perfectly on the Techno CNC interface as well. I am able to preprocess and preview it on the Techno CNC interface. However, once i click on the start button, i get the error and the interface crashes. These are simple contour cuts and pocket cuts. Will someone please help me??? Thanks!
    Mar 2008
    Possible Solution
    Greetings.
    I am certainly not a pro, but I had the same error and found your post while looking for a solution. I got in touch with my Techno rep and he suggested that the tool number I had specified (from my MasterCAM tool library) was too high for Techno to deal with. I changed the number off the tool from 235 to 4 and the programs ran fine. I had changed most of the programs from within MasterCAM, but the one that I missed I changed with the editor in the Techno interface and that worked as well. He also thought there may have been too much extra subset information (in the parentheses) in the programs and suggested deleting that from the .nc files. I did not have to do that, but it is a second option if changing the tool number does not work.
    Good luck.
    Chuck
    Oct 2008
    I need help with this also, anyone that can help me please email me
    Jul 2008
    5
    Runtime Error 9 Problem solved?
    I also have that problem.
    Running RhinoCAM and a Techno 5050.
    Also a newbie...
    Did you guys find a solution for it? Does it come from CAM? Or is it in the Interface?
    Oct 2009
    runtime error
    As stated above, I've gotten this error and have found that it refers to the tool numbering in Mastercam, it is not a problem with the interface. I'm using X3... When I start a new Machine Group, I have an option under Properties >> Tool Settings >> Toolpath Configuration to check "Assign Tool Numbers Sequentially." If not checked, the system may assign a high tool number like #232 (don't know why???). Checking the box, causes tool numbering to start at #1 and it then increases sequentially. If I forget to check that box for a new mach group, I'll get the "Subscript out of range" error when using the interface. Hope that helps.
  1. mori seiki mv junior "jog rset" error
    By Arsonist in forum Uncategorised MetalWorking Machines
    Last Post: 03-25-2010, 12:45 AM
  2. BOSS8 "+Z OVERFLOW" error message
    By jonny in forum Bridgeport / Hardinge Mills
    Last Post: 05-29-2008, 10:12 AM
  3. Help! Leadwell VMC "605: Interlock error"??
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 01-02-2007, 03:06 PM
  4. mazak t1 universal "error 124 n"
    By dohcom in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-23-2006, 02:25 PM
