585,764 active members*
4,378 visitors online*
Results 1 to 9 of 9
    Feb 2011
    7
    Aligning mirrors, laser burn mark is ring shaped
    Hi Cnczone, I'm attempting to diagnose a drop in power on my 100W Thunder Laser Mars. The machine is around 1.5 years old.
    Cleaned mirrors & lens, aligned mirrors, but still low power.
    I noticed the burn mark when aligning the mirrors is creating a ring shape, which as far as I can recall, it wasn't doing before. Does this mean anything to anyone, I can't find any references to this issue in the forums.
    Here's a photo
    Attachment 360886
    Nov 2010
    787
    Re: Aligning mirrors, laser burn mark is ring shaped
    Is this the same before first mirror? If so just the time to buy new laser.
    CNC lasers, constructions, service
    Dec 2006
    76
    Best you contact Nolan at Thunder Laser I'd say. Always appears quite willing to help.
    Feb 2011
    7
    Thanks for the feedback. I've contacted Ben at Thunder laser in addition to posting here. Ben has so far suggested turning the laser power up above 30%, which instantly ignites whatever object is unfortunate enough to get in the beam path I'll post back any more feedback I receive from their end.
    This sticker is sitting just before the last mirror.
    Dec 2007
    31
    Dang, that is a solid fault symptom. I like cinematic's idea, do you see it before the first mirror? This may sound condescending, but have you cleaned the laser output lens?
    Feb 2011
    7
    Quote Originally Posted by MConner View Post
    Ben from Thunder Laser recommended the same as you guys, the image below is a piece of cardboard which ships with the machine with three marks burnt at the tube output (before the combiner). The new marks are measured at 30% (recommended by Ben) and 15% you can see the ring pattern.
    EDIT: Ben replied to say that the laser tube is unstable below 30% power. The best performance is between 30-70%. He suggested I clean my mirrors :-( I'll try buying some new mirrors and re-align the whole thing again.
    Attachment 360976
    Attachment 360978
    Do you mean the beam combiner?
    Dec 2007
    31
    Interesting to learn about the low power stability issue, that is a good thing to know. By output lens, I meant the actual output end of your laser tube itself, inside the gold metal ring in your picture. I have seen residue build up on mine occasionally, most likely from doing test shots with the exhaust off, or collection dust. Good luck.
    Feb 2011
    7
    Thanks for your replies, I'm going to go with "dirty mirrors" and replace them. Ring is normal below 30% power. Machine is great by the way, buy Thunder Laser!! (flame2)
    I should specify, I have cleaned them already but can't get them super clean.
    Jun 2016
    7
    Hey, did you solve this ring shaped mark problem? Was it the tube?
    We have the same problem, but our tube is at 650 hours and it's too soon for its end.
    We have moved to a new location and turned the machine on one side in order to make it through the door (the machine is huge). Maybe this is when something happened?
    The following two weeks we cut a lot of acrylic (successfully).
    Now the machine still cuts ok (with slightly lower intensity), but the engraving is messed up completely.
  1. If there's a laser engraver which no need replace laser tube ,mirrors ?
    By Triumph-support in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-24-2016, 02:51 AM
  2. Strange issue, laser tube burn pattern on test piece is a concentric ring.
    By garagefela in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-16-2016, 03:44 PM
  3. Trouble Aligning Mirrors/Better Mirror Carriage?
    By brcguy in forum Laser Hardware
    Last Post: 12-01-2012, 12:39 AM
  4. Free CO2 Laser Mirrors
    By twehr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-18-2012, 10:09 AM
  5. Steel Ring Egg Shaped and Poor Finish
    By LaysMachinist in forum Material Machining Solutions
    Last Post: 03-01-2011, 07:32 PM
