585,735 active members*
5,019 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Chinese, 220V, 1.5 kW, water cooled spindle motore
    Jul 2010
    22
    Hi Guys,
    I have been rebuilding and rewiring my home built CNC machine and bought a Chinese, 1.5 kW, water cooled spindle. It looks very substantial and thought that it would do what I need it to do. The only trouble is; it came without any wiring instructions for the 3 pin 'Aviation' connector. I bought the item off ebay but the company that I bought it from are no longer listed with ebay. I found out the email address of the company and wrote to them, but as is usual with the Chinese, though promising support; no sign of an answer.
    I have tried working out what the connections are using my multimeter but am no better off because each of the pins is showing 4.2 Ohms between any of the other two pins. My thoughts were that if I could find the ground pin, being AC, it would not matter too much whichever way I wired the other two.
    There appear to be at least three variations of 1.5 kW motors and so I have included pics of the relevant one.
    Has anyone any experience of these? T
    Mar 2007
    2083
    Re: Chinese, 220V, 1.5 kW, water cooled spindle motore
    HI Pader
    your motor does not have an earth pin on that 3 pole connector as its a 3 phase motor that should be powered by a VFD
    you will find other spindle motors for sale with a 4 pin connector that very often only has 3 pins connected !!!!
    a few posts on CNC Zone shows you how to wire the unused pin to the spindle motors case
    from one post I save this -
    Attachment 361038
    John
    The 3 wires go to the U, V, and W terminals on the VFD. If it spins the wrong way, just swap two of the wires.
    Jun 2005
    1729
    Pader,
    You need the matching VFD to power up that spindle. It is critical that you program the VFD with the correct parameters before you start it up or you can damage the spindle and VFD. You should also use a braided shield on the cable from the motor to the VFD, the ground MUST be connected at the Spindle and the shield braid is also connected to the spindle body. Since your spindle only has three contacts those for for the three phase power. You will need to secure the ground and braided shield to the spindle body perhaps with the spindle mounting clamp. The other end of the cable connects to the VFD output power and the ground. The shield for the spindle motor must be grounded at the VFD end. There are several users like MachTec who have posted the setting in the VFD multiple times. Do NOT attempt to power this without using a VFD.
    Russ
    Jul 2010
    22
    Quote Originally Posted by Pader View Post
    Hi Guys,
    Thank you John, Ger and CNCman. I much appreciate your very prompt replies. Of course, the listing did not mention that the motor required a VFD. I suppose I shall have to spend out for one though I am somewhat annoyed because I could have taken advantage of a combined spindle and VFD listing had I known which would have saved me quite a lot of money.
    Thanks once again guys
  1. A Look Inside a Chinese 3.0kW Water Cooled Spindle
    By kevincnc in forum Spindles / VFD
    Last Post: 05-02-2019, 02:57 PM
  2. 4kw Chinese water cooled spindle wiring to VFD Need Help
    By cnccutting in forum Spindles / VFD
    Last Post: 02-22-2017, 05:11 AM
  3. Water cooled Chinese Spindle - air leak
    By analogman in forum Spindles / VFD
    Last Post: 06-23-2016, 02:08 PM
  4. Replies: 1
    Last Post: 04-21-2016, 05:38 AM
  5. Gecko 540 and a chinese 2.2 kw water cooled spindle and vfd
    By skyguynca in forum DIY CNC Router Table Machines
    Last Post: 03-19-2014, 10:00 PM
