Hello. Recently i created a project using 2D profiling & area clearance toolpaths.
My problem is that the cnc cuts the first layer but instead of steping down and continue cutting it repeats the second layer in the same place (20mm material thickness/ tool stepdown 5mm, so it move 4 times in the same place).
Every setting seems ok... i also attached the file in order to check it. By the way, in similation it works great.
Iam using artcam pro 9.1
