585,974 active members*
4,191 visitors online*
Results 1 to 7 of 7
    Mar 2014
    735
    Y - axis drive plate and NEMA 34 motor mount
    Hello -
    I have 2 parts I would like a quote on producing and I need 3 of each part. Both parts are from hot rolled (common) 5/16" steel plate. The Y- axis drive plate would be ideal for a water jet machine. The NEMA 34 motor mount has some pocketing work in the center. I have dxf files of each part. For the NEMA 34 mount I will attach a photo of a prototype and add the pocketing depths by hand with a photo editing program. I don't have access anymore to AutoCad or similar design program and I'm just learning Fusion 360. Please ask if any interested party needs additional info and I will be happy to provide if I can. Tolerance should be within .002" on all dimensions.
    Photo with pocketing depths attached.
    Feb 2006
    196
    Re: Y - axis drive plate and NEMA 34 motor mount
    1Jumper,
    We would be interested in quoting your project. Please send the image with depths so we can determine what might need corner radii.
    Doug Pryor
    David Wolfe Design, Inc.
    Akron, OH
    www.davidwolfedesign.com
    [email protected]
    Mar 2014
    735
    Dpryor -
    I attached the photo with pocket depths. The part is intended to mount a NEMA 34 gear box. I have the dimensional drawing of the gearbox if it would help, but the corner's of the gearbox are beveled so any radius up to about 1/4" should work fine. I will email you a couple photos.
    Feb 2006
    196
    The photo is too pixelated to read. Can you just email it? Thanks.
    Doug Pryor
    Akron, OH
    [email protected]
    Aug 2010
    57
    If you'd like you can share the project with me on Fusion360 for the quote. My email is [email protected], that should be how to find me.
    William Brantingham
    May 2015
    23
    Pm Sent.
    Thanks, Matt Mittler
    Mittler Machine Works
    [email protected]
    Mar 2014
    735
    I have replied to all PM's thank you all for your quotes. Unfortunately I seem to have underestimated the cost for this and will have to go a different route. FYI - all the estimates I received were very similar in cost. Thanks again.
  1. Motovario 15:1 gearbox W/ Nema 23 motor mount
    By SwampDonkey in forum For Sale Only
    Last Post: 07-01-2023, 07:45 PM
  2. gecko drive and nema 23 motor - resistors
    By neattimes in forum Gecko Drives
    Last Post: 07-23-2015, 01:34 PM
  3. Nema 23 8 wire motor to Gecko drive
    Last Post: 12-14-2014, 03:00 AM
  4. simple nema 23 motor mount pdf
    By freddean2006 in forum DIY CNC Router Table Machines
    Last Post: 11-08-2008, 04:02 AM
  5. Nema 23 & 34 Motor Mount Wizard
    By Fred Doerr in forum Mach Software (ArtSoft software)
    Last Post: 11-24-2006, 02:30 AM
