Hot Sale Non-metal Co2 Laser Cutting And Engraving Machine FM-E1309 120W Laser Tube
Product features:
- Drive system with high precision linear guide and slide block, high precision, wear resistance, small resistance, high speed; arc-gear synchronous belt 3m, stable transmission, strong shock absorption ability and small noise.
- Interlocking door with auto-shutdown protection device.
- Red Cross accurate positioning, convenient and quick in finding engraving and cutting position.
- Imported linear guide and the latest 32bit ARM processor to control the stepper motors and drives, the effect of cutting edge is smooth without ripples;
- Three-mirrors and one focal lens path system to deliver outstanding engraving and cutting effect;
- Large visualization protection window
- Adopt integration frame structure design, make the machine running stable no noise;
- The operation is simple, can be carved the order, the processing level, which can realize partial or all of the one-time flexible output laser power, speed, focal length adjustment;
- Open software interface, compatible with DXF, ai, PLT, DST, DSB and vector file such as BMP, JPG, GIF, PNG, MNG, equipotential graph format.
- Equipped with water protector, better protection of laser, prolong the service life of laser, optional foot switch, make your operation more convenient.
- Elegant appearance design;Super strength steel plate, industrial grade;The effective protection of equipment running smoothly and life;
- Double guide rail;Belt drive;Can choose to configure the hive article/case/tablet/lifting;
- Patent technology: unique automatic convulsions smoke dust removal system Blow air protection .
The equipment parameters:
Model FM-E1309 FM-E1610 Working Area 1300*900mm 1600*1000mm Laser Power 80W/100W/120W/150W/180W Laser Type CO2 Sealed Laser Tube,10.6μm Cooling Type Water Cooling Engraving Speed 0-20000mm/min Laser Output Control 0-100% Set by Software Min.Engraving Size Chinese:2.0mm*2.0mm,English Letter:1.0mm*1.0mm Highest Scanning Precision 2500DPI Locating Accuracy ≤+0.01mm Controlling Software DSP Control System Graphic Format Supported DST PLT BMP DXF DWG AI LAS,etc Compatible Software TAJIMA,CORELDRAW,PHOTOSHOP,AUTOCAD,All type of AUTOCAD Sofeware in Cloth Drive System High-precision Stepper Motor Auxiliary Equipments Exhaust Fan and Air Exhaust Pipe Power Supply AC110V/220V±10%,50HZ/60HZ Working Environment Temperature:0-45C,Humidity5-95%(No Condensate Water) Option Up&Down Table, Honeycomb Worktable, Rotary Device, Auto-focus Device
Application in industry / Materials:
Material Cut Engrave Acrylic, Plexiglass, Pmma, Perspex, Organic board, Double color plate √ √ Plastic, PP, PET, PC, PMMA, PS, PES, PA, Plastic Foils&Films, Polycarbonate, polyester or polyimide membrane keyboards √ √ Wood, Bamboo, Veneer, MDF, Blasa wood, Plywood √ √ Leather, Pig leather, Cow Leather, Sheep leather √ √ Textile, cotton, silk, felt, lace, synthetic & technical textiles, aramid, polyester, fleece √ × Foam& Filter, Mats Polyester (PES), Polyethylene (PE), Polyurethane (PUR) × × Neopren × × Paper, Cardboard, Chipboard, Press Board √ √ Stone, Ceramic, Granite, Marble, Natural stone, Pebble stone, Slate √ √ Rubber stamps, Synthetic & Silicone Rubber, Natural rubber, Microporous foam √ √ Silicone rubber, Synthetic rubber √ √ Glass,Pressed glass, Float glass, Crystal glass, Mirror glass × √
Packaging / Shipping1.Our wooden case is after fumigation treatment.Needn't timber inspection,saving shipping time.
2.All the spare parts of the machine were covered by some soft materials,mainly using pearl wool.
Avoiding all damages that could happen in the delivery process.Then we'll covered plastic wrap out it tightly,make sure intact of the covered soft materials,also avoiding Waterproof and rust proof.
3.The outmost is wooden case with fixed formwork.
4.The bottom of the wooden case has firm iron jack,convenient to Handling and transport.
Note: the payment the remit first, then shipping, delivery, cycle 15 workdays.
About MEIMAN LASER
Shandong Meiman Laser Technology Co., Ltd.Is an innovative high-tech company specialized in laser marking, engraving, equipment-cutting.
"World laser technology for better life" is the vision of Meiman laser.
"innovation, breakthroughs, efficiency and service-orientation" are the core concept in the development Meiman laser.
We are proficient in laser technology as well as in product design.
We offer our customers customized solutions and technical services.
Contact me
Yoyo
[email protected]
whatsapp: +8615634089575
skype : [email protected]
our website : www.meimantech.com
Add:Huaqiang international Building A ,NO.157.Shanda Road. Lixia Zone.Jinan City. China
