Fired the machine up and homed the axis, one made a funny noise and then pathpilot went into error, x-axis wouldn't come off the limit switch when it homed.
Reset and reset, powered down and tried again, no movement on the x axis removed the cover and moved the axis off the limit manually.
Same thing, pathpilot thinks it's moving (DRO moves) but nothing is happening (no noises or anything.
Opened the cabinet and there is a red light on the drive. Swapped motor plug over to the y-axis (y axis ply has a big black burn mark on one pin, may have to look at that as well, seems I saw it happened to someone else and they solder different connector on) and moved the table out of the way on the x so the motor is fine.
Guess it's time to order a new drive, tormach looks like the only source without waiting a month.
Bummer
M
