585,705 active members*
4,088 visitors online*
Results 1 to 3 of 3
    Mar 2010
    hiwin stainless balls
    Hi!
    I'm Siro From Italy.
    I'm building my own CNC.
    I need help to find stainless balls replacement for my 4 HGW20 Hiwin.
    Someone can confirm the balls size? They should be 3,969mm or 5/32''
    Please Help me!
    Jul 2006
    3
    Re: hiwin stainless balls
    Why do you want to use stainless steel for the bearing balls? If you're using standard linear rail it's still made from En31/52100 or similar material and can corrode. 440C balls are a good choice if you need stainless properties, be sure to use Grade 25, lower precision grades may not give the accuracy or wear life you want.
    5/32" 440C Gr25 balls are available from many USA suppliers, a quick web search will find them. Be sure they will ship overseas.
    falacncrouter Guest
    Stainless steel ball screw for cnc router. Why not choose Taiwan TBI ball screw?
  1. Replies: 0
    Last Post: 05-14-2016, 09:09 PM
  2. Replacement balls for out of production hiwin carriages (LGH15)
    By adfergusson in forum Linear and Rotary Motion
    Last Post: 03-30-2015, 12:32 AM
  3. Lets do some trading? Hiwin 30mm for Hiwin 25mm
    By hacker7 in forum Open Source CNC Machine Designs
    Last Post: 06-22-2013, 06:51 PM
  4. stainless balls "freeze" in tub
    By CaptainVee in forum Mass finishing equipment/media/strategies
    Last Post: 06-15-2013, 01:23 AM
