585,744 active members*
3,906 visitors online*
IndustryArena Forum > Mechanical Engineering > T-Slot CNC building > MY T-SLOT MACHINES: CNC ROUTER AND FOAM CUTTER
    Nov 2011
    107
    Cool MY T-SLOT MACHINES: CNC ROUTER AND FOAM CUTTER
    I have always liked the practicality of the extruded aluminum. Very easy to build machines from the ground.
    My last router was inspired by the Shopbot Desktop: I wanted something to be sturdy like a tank within a small form factor. It uses Leadshine drivers integrated into the machine body along with all the electronics. The ESS for the train pulse generator and a 1hp spindle form UGRA (first time to use a spindle, I was using a Bosch router and a super PID and i will never come back).
    All the frame was built using extruded aluminum.
    Attachment 362142
    All the ballscrews are from ebay (linearmotionberings)
    Attachment 362144
    Just like the shopbot, the first proyect was to make a spoilboard and a magnetic dust shoe
    So far so good, I been cutting aluminum very easely, just had to add some coolant, a choose the MD-1200 Microdrop.
    https://youtu.be/fd2pTnycNtg
    Currently im concerned about Mach3, i have read that a lot of people are switching to UCCNC, what do you guys think about it??
    My last build is a foam cutter, and again i built it with 20 mm extruded aluminum, currently im working to improve the cutting speed and the cutting temperature, trying to add a PID controller, I'm looking for the right thermocouple, any suggestions?
    Attachment 362146
    Im using it with Simplify3d to control it, this foam cutter is powered by the smoothieboard.
    https://youtu.be/AKgKzSsWntw
    Dec 2017
    Re: MY T-SLOT MACHINES: CNC ROUTER AND FOAM CUTTER
    What kind of tolerances could you hit with with this machine cutting aluminum?
    Feb 2019
    7
    Thanks for posting this. I'm designing a similar but smaller machine that is built in similar way with extrusions and linear guides / ball screws. Hoping I can get similar cut rates and quality to yours when cutting aluminum. I found your blog and also thought that was good resource.
    What stepper size / torque did you use?
    Are you using the 800W spindle you showed in the blog in that video?
    Thanks!
    -Todd
  1. CNC FOAM CUTTER/ROUTER
    By Lafayette in forum CNC Wire Foam Cutter Machines
    Last Post: 08-22-2010, 09:58 AM
  2. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-10-2008, 03:02 AM
  3. CNC Foam cutter/Router conversion
    By skyborne98 in forum DIY CNC Router Table Machines
    Last Post: 11-01-2007, 01:38 AM
  4. Replies: 6
    Last Post: 06-18-2005, 05:19 PM
  5. Foam Cutter/Router
    By CADkathy in forum CNC Wire Foam Cutter Machines
    Last Post: 11-19-2004, 04:30 PM
