585,975 active members*
4,615 visitors online*
    Mar 2007
    Anilam 3300mk Problem
    Hell Everyone
    I have a question about a problem with a Anilam 3300mk controller and was wondering if anyone else has came across this same problem I’m having….well I know other people have had this problem because I looked at all the Anilam posted messages with this forum but didn’t get a answer in any of them. Here is the problem, when I use the G code converter to make a program conversational and when verify it with Draw then Run I get all these crazy radii in the back plot then this message (WARNING ARC ADJUSTED BEYOND MAXIMUM) when ever it has an arc move in the program. The program has been run in the G code format on another machine with no problems. I have checked the conversational program on two other computers with different Anilam offline keys with the same results so it’s not the controller unless the common software (Anilam) is the issue. This machine will not 2D or 3D any converted programs.
    Jan 2007
    20
    Quote Originally Posted by quincy View Post
    Hell Everyone
    are you useing absolute, or incremental circle centers in your programming?
    find this out, then you can change the anilam control to use the same in operator setup - control software parameters.
    you can change this in the offline anilam software also
    Jan 2010
    23
    I am looking for a Anilam 3300 Mk control system for parts. Any help would be appreciated. Please call Larry at 801 216 4576. Thank you
  1. Amilam 3300MK
    By Durby in forum DNC Problems and Solutions
    Last Post: 04-14-2013, 07:38 PM
  2. Anilam Help
    By Turk88 in forum Controller & Computer Solutions
    Last Post: 04-14-2013, 02:14 PM
  3. Anilam 3300MK
    By Buried in forum DNC Problems and Solutions
    Last Post: 05-02-2012, 05:36 PM
  4. Any experience with Anilam 3300MK control?
    By CNCBoss in forum Uncategorised MetalWorking Machines
    Last Post: 02-17-2011, 02:01 AM
  5. My New/Old Anilam Crusader M has a problem
    By L98FIERO in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-15-2008, 01:10 PM
