585,708 active members*
3,857 visitors online*
    BEST SHELL MILL / FACE MILL FOR LAMINATED HARDWOOD
    Right now we are using a standard TPG insert 3" body with 5 inserts. I do a lot of full sheet nesting on a Gantry Router and am trying to find a faster way to mill down large areas in thickness. We are currently doing a 75% step over at 5000rpm and a 0.100" step down. Does anyone have any better ideas? The spindle is a 15hp 10,000 rpm spindle.
    May 2017
    56
    Re: BEST SHELL MILL / FACE MILL FOR LAMINATED HARDWOOD
    The best option to mill laminated hardwood as fast as possible would be a Diamond Coated Insert with positive free cutting top rake allowing you to at higher RPM at a deeper Axial DOC (or step down, I'd keep the step over the same). Here is info on the cutter I'd recommend:
    Cutter: 3" Dia x 1" Arbor x 5 Flute x 45° Facemill
    https://www.toolhit.com/collections/...ts/fmaca4300hr
    Inserts: SEET Diamond Coated Inserts with .031" Corner Rad (4 Corners on a Insert)
    https://www.toolhit.com/products/seet14magfn-ma-pd2000
    Here are parameters:
    Stepover: 75%
    Axial DOC (or Stepdown): 0.150"
    RPM: 6,600 (Cutter is balanced to 13,000 RPM)
    CLPT: .004"-.014" (start at .006")
    IPM: 198
    This is a 45° cutter making it a free cutting face mill, that along with the positive geometry of the inserts allow for a deeper stepdown that won't be an issue for the 15 HP spindle. The Diamond Coated Inserts will give you the best tool life possible in the laminated hardwood and will allow you to run at higher RPM. Let me know if you have any questions on this. Hopefully it helps!
    Mike
  1. Help ID this shell/face mill
    By PandAtool in forum CNC Tooling
    Last Post: 02-27-2013, 06:14 PM
  2. Where to find Shell mill / Face mill arbor for taig
    By 725franky in forum Taig Mills / Lathes
    Last Post: 11-18-2009, 11:48 PM
  3. Face/Shell Mill Arbor
    By Zumba in forum Uncategorised MetalWorking Machines
    Last Post: 05-21-2006, 04:01 AM
