585,556 active members*
3,566 visitors online*
Thread: axis change
    Apr 2011
    68
    axis change
    Have Mach 4 latest build Lathe , I need to change Z axis to X axis , because my Bobcad v 29 lathe does not write the gcode to the correct axis , for my machine . I have talked to Bobcad for a week , no results . Need help
    Aug 2006
    670
    Re: axis change
    you should be able to configure your post processor in bobcad to switch the axis. I assume you're using the Z axis the rotational axis of the lathe, and X for the cross slide?
  1. Change X axis for longer one = change motor ?
    By nicolasd5150 in forum Chinese Machines
    Last Post: 04-27-2015, 01:46 PM
  2. Replies: 2
    Last Post: 08-20-2013, 01:23 AM
  3. Change Facing Axis
    By canyon289 in forum Mastercam
    Last Post: 09-20-2011, 01:21 AM
  4. Can you change a Machine Axis?
    By steve meek in forum Chinese Machines
    Last Post: 11-11-2010, 12:44 PM
  5. Change AXIS GUI
    By Robertz in forum LinuxCNC (formerly EMC2)
    Last Post: 10-13-2008, 08:42 PM
