585,930 active members*
3,716 visitors online*
Page 2 of 3 123
Results 21 to 40 of 45
  1. #21
    This is my DC link cables
    Enviado desde mi GT-I9300 usando Tapatalk
  2. #22
    May be is wrong cable
  3. #23
    The problem its only in the last SVM for 4th axys
    Sent from my iPad using Tapatalk - now Free
  4. #24
    Aug 2007
    793
    no, your wires are ok
    but as I see, there is not ready state on second drive ("-"), but on another "0" - ready
    if your drive is under abnormal condition it usually shows the alarm number, in your case must be "2" or "5"
    I faced with similar problem when one of my drives showed "-", while other drives showed "0". but my CNC showed "improper VRDY off", I replaced this drive and din't figure out what happened with it so far.
  5. #25
    So
  6. #26
    Aug 2007
    793
    I think we should dismantle your drive
  7. #27
    Ok do u have some manual???
  8. #28
    Aug 2007
    793
    all manuals are present on internet
    we need just head, hands and tools
  9. #29
  10. #30
    Aug 2007
    793
    I forgot to ask
    was that drive at this machine from the begining or you tried to upgrade your machine with 4-th axis?
    I mean may be some trouble with parameters?
  11. #31
    I do an upgrade to 4th axis in my VMC. I have all cables and motor connected . I did changes in my 8000's parameters and 900's
  12. #32
    Aug 2007
    793
    8000s, those which are get dowloaded from servo eprom?
    what about FSSB settings 19xx?
  13. #33
    I dont take those parameters !!! Only 8000 and 900s
  14. #34
    Aug 2007
    793
    http://www.cnccenter.com/pdfs/1546.pdf
    catch the link to appropriate manual
    if you faced with difficulties I'm ready to take a part in your project, but through PM, so as this work will take some time
  15. #35
    Thanks my friend let me see this attch.
  16. #36
    My SVM is not FSSB interface
  17. #37
    Aug 2007
    793
    sorry, I'm wrong
    you are right
    ok
    could you swap control cables with neighbour drive
  18. #38
    Aug 2007
    793
    these manuals can help you
  19. #39
    Yes i did and the same alarm 444 DGN bit#6 LV
  20. #40
    Aug 2007
    793
    with which axis have you swapped the cables?
    the fault had to move to another axis, i.e. now it must be on another axis 414 or 424 or 434, but not 444
Page 2 of 3 123
  1. Fanuc 21-tb alarms
    By Hlynur in forum Fanuc
    Last Post: 12-06-2012, 04:44 AM
  2. Fanuc OT alarms
    By cncmike92 in forum Daewoo/Doosan
    Last Post: 04-23-2007, 01:57 PM
  3. Haas VFE alarms
    By TGriz in forum Haas Mills
    Last Post: 10-02-2006, 07:01 PM
  4. Fanuc 6MB 401 and 410 alarms
    By john braks in forum Fanuc
    Last Post: 02-24-2006, 07:45 AM
  5. Drive alarms
    By nervis1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-05-2006, 10:02 PM
